sears power washer for air compressors? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2005, 07:19 AM
New Member
anyone try one of these? Item#00916225000 go to sears.com and check it out. it says it sprays 2.2scfm @50psi w/min 3hp compressor. I was wondering what this could be used for? and how would it compare to wallyworld's powerwashers.....
Old 01-01-2006, 07:30 PM
Last journal entry: frame build
I made one out of a dollars worth of coppertube and an air coupler. Not so fancy but works well a a solvent sprayer. Adjust airpressure with a regulator and use goggles ,rubber gloves and respirator. Put a weed sprayer nozzle on it and you can even adjust the patteren from stream to mist.
Have fun
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Power Steering and Power Brakes blindboarder711 Suspension - Brakes - Steering 1 02-09-2004 02:54 PM
Car Audio Question Thuggishruggish3000 Interior 14 12-23-2003 08:48 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
