seat backs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2010, 11:29 AM
phanline6.6's Avatar
seat backs
Does anybody know how to get the seat backs on the front seats of a 1980 firebird?
Old 01-12-2010, 09:50 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Are you asking how to put on the seat back cover or put the seat back onto the seat base? Any seat back in a two door car or a bench seat in a pickup truck that tilts forward has to hook over a post on both sides. One or both sides will have a bolt or a cotter pin to hold it in place.
Old 01-13-2010, 04:15 AM
Seat back cover. They came with the car, just not installed, I'm beginning to understand why. I just can't see how they attach. I thought someone may have had this problem and figured it out.
Old 01-13-2010, 07:01 AM
Wiki Edits: 22
Does the seat cover look something like this? CLICK HERE In any event, the cover needs to be turned inside out to start with. Then any areas that have listings and wires have to be attached to the seat with hog rings. This cover looks like it has two listings, one horizontal at the bottom, and one horizontal farther up. There also are probably listings that go vertically on both sides. Attach the horizontal listings first, and then attach the vertical listings. After that, the cover gets turned right side out over the top of the seat frame.
If you can post pictures of the inside and outside of the cover, I can tell you exactly.
Old 01-13-2010, 07:48 AM
I'm talking bout the hard plastic that covers the back of the backrest. The bottem attaches down on the seat hinge, the top, I have no idea where it attaches
Old 01-13-2010, 10:19 AM
Wiki Edits: 22
Sorry, I misunderstood your question. Somewhere at the top of the plastic back there are usually a couple of built in plastic loops that hook over some metal pieces on the seat frame. That holds the top and then you screw down the bottom. If the loops are broken off, you will need a new back piece.
These pictures are of a Corvette seat back. The two metal pieces are visible in the first picture, and the second picture shows the seat back. It has 4 holes at the top that get retainers screwed to them. The retainers go over the two metal pieces and hold the top of the seat back. The last picture is with the retainers screwed in place.
ID:	43201   Click image for larger version
ID:	43202   Click image for larger version
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Corvette Seat Cover Replacement DanTwoLakes Interior 7 03-29-2009 01:19 PM
Re-padding an old car seat. DanTwoLakes Interior 9 09-23-2008 06:52 AM
Modifying bench seat frame Brimstone Interior 10 07-30-2007 11:22 AM
Power Seat Wiring Info Needed- Mid 70's Chevrolet/Chevelle LongTom Electrical 1 02-06-2007 01:36 PM
