Seat belt mountings nuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2007, 03:13 PM
I am installing retractable seat belts/shoulder harnesses in a 64 1/2 Mustang that never had them from the factory and I need some decent mounting holes in the floor at the rocker, actually the inside of the rocker. I can not get to the inside to use nuts because this goes into the rocker from the inside of the car so what I need is some kind of nut (1/2" fine thread) that I can insert into the hole and have it expand and anchor tightly. The ones I am familiar with that would work I can't find and in fact have not seen any in years. Everything else I am finding looks as if it may not anchor tight enough even though the metal in that area should be strong enough to do the job. Any suggestions?
Old 10-30-2007, 03:41 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Those kind of nutplates are hard to find..What I would do is to cut some of the nutplates out of another car and weld them in so I have nutplates in the correct spot..
Hope this helps
Sam
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Seat Belt Restoration 383 Camaro Interior 8 05-23-2007 12:23 PM
seat belt question romeyw Interior 4 01-12-2006 05:19 AM
Internal 3pt seat belt electrical release bfr57 Interior 2 04-10-2004 03:05 PM
Internal 3pt seat belt electrical release bfr57 Electrical 2 04-09-2004 12:25 AM
