seat belt question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2006, 08:35 PM
seat belt question
the seat belt does not roll back in the like it should with out helping it . I was thinking the springs that pull the belt need oiling. Any one else has this problem ?
Old 01-06-2006, 11:10 PM
arch's Avatar
My bike has 4wheel disc brakes
Possibly, but most likely the spring is worn out and needs to be rewound or replaced.
Old 01-08-2006, 07:58 PM
seat belt question
You might try cleaning the windup mechanism, and also see if the belt has rolled over.
Old 01-08-2006, 10:26 PM
73oldsman's Avatar
I had the same problem with my Olds years ago. I pulled the plastic cover from over the seatbelt mechanism. The belt was exposed , along with a plastic housing. I carefully pried the round plastic housing that holds the tension spring for the belt. It was not broken in any way and I was able to wind the spring tighter and reclip it back in the housing. I then put it back on the seat belt bracket set-up the same way it came off. I still have the seat belt in the car and it still works. Maybe this will work for you or it may be broken and needs replacement. Good luck!
Old 01-12-2006, 05:19 AM
thank you all
thank you all for yall help
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Question about re-covering seats. speedingpenguin Interior 1 12-10-2004 12:35 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
1969 Cutlass bucket seat question energenie Interior 0 10-25-2003 11:26 AM
Seat repair question Stinkin_V8 Interior 1 02-14-2003 07:25 PM
