seat belts ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2005, 04:46 PM
steve t's Avatar
ex biker, now hotrodder
seat belts ?
in N C do you have to put seat belts in your old car if it never had them? i know, you should wear them
Old 04-20-2005, 10:13 PM
1Fast65Elky's Avatar
Left Nut, Right Nut....Squish!
put em in anyway, you'll be happy if you ever do get hit or pulled over. Takes 30 minutes or so and will save you more in the long run.....
Old 04-25-2005, 07:27 AM
I agree. Play it safe and put them in anyway. Juliano's is the big name and you can see what's available. Also try Andover Restraints for some good looking belts at good looking prices. USe DOT approved belts and don't skimp and get used ones.
Old 04-25-2005, 09:46 AM
poncho62's Avatar
Wiki Edits: 5
Don't know in your area, but here, it only had to have the belts if it originally came with them. Got stopped a couple of times in my 55 Chevy.....no ticket, but you still get the lecture.
Finally put belts in my old cars when the grandchildren came along.
Ontario Rodders
Old 04-26-2005, 09:42 AM
willys36@aol.com's Avatar
Wiki Edits: 21
I go to Pick-A-Part and get seat belts for every car I build. Willys has 'em, '53 Chevy pickup has 'em.
Old 04-26-2005, 10:04 AM
daimon1054's Avatar
I know of no law that says you have to add them if they did not have them but I don't know all the laws. I also have found the DMV to be next to usless as the bums there know even less of the law all they do is push papers and try to act important. I would call your state police or do internet searches. As said for safety I would mount some but I would want 3 point units not just lap belts.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Where to find seat belts WakBordr7387 Interior 9 01-08-2005 10:19 PM
Where to get seat belts? BobbyG-39 Interior 3 08-18-2004 10:23 PM
Up grade El Camino seat belts stinky jinx Interior 1 12-26-2003 03:16 PM
Upgrading rear seat belts? Jag Daddy Interior 1 04-30-2003 04:29 PM
