-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   seat cover (http://www.hotrodders.com/forum/seat-cover-24892.html)
78 chevy truck 10-03-2003 09:40 AM
seat cover
is there a web site show you step by step how to make a truck beach seat cover
kristkustoms 10-04-2003 08:09 AM
Horvath will tell you about some really good books....
Maybe i could help, does the seat currently need new foam or help with the springs (depending on what your seat has)? Is the cover that is on it totally shot, or is it just wearing out?
WTR4LIFE 10-04-2003 05:20 PM
Seat Springs, my passenger seat springs feel like they need to be replaced, the seats slopes to the outside, care to enlighten me on how to fix this krist?
kristkustoms 10-05-2003 08:37 AM
If the springs are broken, then you need to replace the springs. Even if they arent broken, replacing the springs is your best bet...
First need to find out if they are "S" springs or a coil type of spring. The "S" springs are ready available from any upholstery supplier, the coil springs are getting harder to find. My guess is they are coils, and if they are sagging, simply get some dense foam scraps, cut into small chunks. Stuff the foam into the coils until it stretches back to the original height. Now the stuffed foam springs will use the density of the foam as the "spring," and your seat should be back to normal.
