seat cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2003, 10:40 AM
seat cover
is there a web site show you step by step how to make a truck beach seat cover
Old 10-04-2003, 09:09 AM
kristkustoms's Avatar
First name...............Shawn
Horvath will tell you about some really good books....
Maybe i could help, does the seat currently need new foam or help with the springs (depending on what your seat has)? Is the cover that is on it totally shot, or is it just wearing out?
Old 10-04-2003, 06:20 PM
WTR4LIFE's Avatar
New Member
Seat Springs, my passenger seat springs feel like they need to be replaced, the seats slopes to the outside, care to enlighten me on how to fix this krist?
Old 10-05-2003, 09:37 AM
If the springs are broken, then you need to replace the springs. Even if they arent broken, replacing the springs is your best bet...
First need to find out if they are "S" springs or a coil type of spring. The "S" springs are ready available from any upholstery supplier, the coil springs are getting harder to find. My guess is they are coils, and if they are sagging, simply get some dense foam scraps, cut into small chunks. Stuff the foam into the coils until it stretches back to the original height. Now the stuffed foam springs will use the density of the foam as the "spring," and your seat should be back to normal.
