-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Seat dimensions (http://www.hotrodders.com/forum/seat-dimensions-218324.html)
OneMoreTime 04-19-2012 10:07 AM
Seat dimensions
I need to build some bomber seats and would like some input on dimensions in order to allow some room for padding..
Sam
Irelands child 04-19-2012 10:46 AM
Sam
Sam - are these what you are looking at building? These are Eddie Barrett seats out of CT. If that's what you need, then I'll measure them up:
http://i70.photobucket.com/albums/i8...d/DSC_0073.jpg
I have a set of Speedway runners and a 2-3" or so riser under them as well:
http://i70.photobucket.com/albums/i8...d/DSC_0071.jpg
(That long adjuster lever/rod has been cut off since the photos were taken)
Dave W
OneMoreTime 04-19-2012 12:35 PM
Yes Dave that is it..Mine will be a bit higher on the sides like a race seat and I will incorporate head rests by making the backs higher..Of course i will need to do a bit of adaptation to my shop equipment to make them..I have decided to work out my seating and legroom before I install the engine so I can get the engine mounted as far back as possible...
Thanks
Sam
Irelands child 04-19-2012 01:31 PM
Thanks
Sam
Sam - CRS and being the OF that I am, have forgotten what you are building. If it's an 'A' or something similar in size, I do have to caution you about engine setback as it has a strong implication on your seat design, legroom and ease of access. I have a pair of beautifully done Glide Engineering seats sitting in my basement I can't use with any sort of comfort in my '31 - too bulky. I am 6'4", but not hefty at ~200# and even the seats I have could go back another 3-4 inches and be angled some more - but that's the room I have to work with. And it was all determined by my engine setback - see below:
http://i70.photobucket.com/albums/i8...d/DSCN1748.jpg
Then it gets interesting to install gauges and heater or a/c:
http://i70.photobucket.com/albums/i8...d/DSC_0232.jpg
That's the heater. I had an a/c originally but decided that with a roadster, kinda useless - but at least my toes are toasty.
But - you probably know all of this :mwink:
For your reading enjoyment I'll lay a tape/scale in several different directions on the seats, photograph, and probably first thing in the morning.
Dave w
OneMoreTime 04-19-2012 01:59 PM
Cool..The car I have is close to a channeled A in size and I have 52 inches from the seatback to he firewall so once I get the seats made I can set in there and see just where the firewall will go..makes perfect sense to me to do it that way.. :embarrass
Sam
Irelands child 04-19-2012 05:26 PM
Sam - I got a chance this evening before going out to do some photos and measuring for you. Add 3-1/2 inches to the dimension you see on the tape for the housing(33' tape):
Firewall to seat back - ~42"
http://i70.photobucket.com/albums/i8...atmeasure4.jpg
Height of seat - ~8-1/2
http://i70.photobucket.com/albums/i8...atmeasure3.jpg
Width of seat - ~18"
http://i70.photobucket.com/albums/i8...atmeasure2.jpg
Seat back to brake pedal - ~36"
http://i70.photobucket.com/albums/i8...atmeasure1.jpg
Height of seat back - ~18"
http://i70.photobucket.com/albums/i8...atmeasure5.jpg
I 'forgot' to photo the overall firewall to cockpit rear padding, but it is ~52"
Let me know if you need any more.
Dave w
OneMoreTime 04-19-2012 07:47 PM
That is great Dave..All I need to start fabricating the seats..your car is very similar in size to mine..
Thanks
Sam
