Seat dimensions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2012, 11:07 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Seat dimensions
I need to build some bomber seats and would like some input on dimensions in order to allow some room for padding..
Sam
Old 04-19-2012, 11:46 AM
Irelands child's Avatar
Sam
Sam - are these what you are looking at building? These are Eddie Barrett seats out of CT. If that's what you need, then I'll measure them up:
I have a set of Speedway runners and a 2-3" or so riser under them as well:
(That long adjuster lever/rod has been cut off since the photos were taken)
Dave W
Irelands child
Old 04-19-2012, 01:35 PM
Wiki Edits: 3
Yes Dave that is it..Mine will be a bit higher on the sides like a race seat and I will incorporate head rests by making the backs higher..Of course i will need to do a bit of adaptation to my shop equipment to make them..I have decided to work out my seating and legroom before I install the engine so I can get the engine mounted as far back as possible...
Thanks
Sam
Old 04-19-2012, 02:31 PM
Thanks
Sam
Sam - CRS and being the OF that I am, have forgotten what you are building. If it's an 'A' or something similar in size, I do have to caution you about engine setback as it has a strong implication on your seat design, legroom and ease of access. I have a pair of beautifully done Glide Engineering seats sitting in my basement I can't use with any sort of comfort in my '31 - too bulky. I am 6'4", but not hefty at ~200# and even the seats I have could go back another 3-4 inches and be angled some more - but that's the room I have to work with. And it was all determined by my engine setback - see below:
Then it gets interesting to install gauges and heater or a/c:
That's the heater. I had an a/c originally but decided that with a roadster, kinda useless - but at least my toes are toasty.
But - you probably know all of this
For your reading enjoyment I'll lay a tape/scale in several different directions on the seats, photograph, and probably first thing in the morning.
Dave w
Irelands child
Old 04-19-2012, 02:59 PM
Wiki Edits: 3
Cool..The car I have is close to a channeled A in size and I have 52 inches from the seatback to he firewall so once I get the seats made I can set in there and see just where the firewall will go..makes perfect sense to me to do it that way..
Sam
Old 04-19-2012, 06:26 PM
Sam - I got a chance this evening before going out to do some photos and measuring for you. Add 3-1/2 inches to the dimension you see on the tape for the housing(33' tape):
Firewall to seat back - ~42"
Height of seat - ~8-1/2
Width of seat - ~18"
Seat back to brake pedal - ~36"
Height of seat back - ~18"
I 'forgot' to photo the overall firewall to cockpit rear padding, but it is ~52"
Let me know if you need any more.
Dave w
Irelands child
Old 04-19-2012, 08:47 PM
Wiki Edits: 3
That is great Dave..All I need to start fabricating the seats..your car is very similar in size to mine..
Thanks
Sam
dimensions steve metzler Suspension - Brakes - Steering 0 02-26-2012 05:31 PM
New Unused Bucket Seat Complete Set 2 Bucket & Middle Seat Console seatsman Interior 1 11-01-2011 12:27 PM
Bench Seat Swap To Bucket Seat Help arnellwest Hotrodding Basics 11 03-28-2011 11:50 PM
shock dimensions racer rick Suspension - Brakes - Steering 3 06-02-2007 10:01 PM
SS stripe dimensions? HELP ME M&M CUSTOM Body - Exterior 13 06-26-2005 06:55 AM
