-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Seat Heaters (http://www.hotrodders.com/forum/seat-heaters-208386.html)
slodat 11-08-2011 01:40 PM
Seat Heaters
Has anyone used one of the seat heater kits out there? I picked one up from Perfect Fit the other day. Plan is to put it in a seat I am upholstering later this week. Thought I'd see if anyone has any tips, tricks or hints on using them.
The seat bottom has a listing wire that the heater will cross. The included instruction sheet say you can cut a hole in the heater pad to pass the listing through.
DanTwoLakes 11-08-2011 01:50 PM
Heaters are very simple, just stick them under the insert area of the seat cover, and run the wire out the back. There must be some adhesive strips either built in to the heater pad, or separate. If you can cut the hole through for the listing, I would do that first and then hook it up to power to make sure it works before closing it up inside the seat. I think there must be only certain areas you can cut, so make sure you read the directions very carefully. Good luck.
slodat 11-08-2011 01:54 PM
That's the part I haven't sorted out in my head yet. In the seat bottom pictured below, how do i manage the side-to-side listing?
https://lh4.googleusercontent.com/-E...0/IMG_4788.jpg
DanTwoLakes 11-08-2011 02:32 PM
Are these carbon fiber heaters? I think as long as you don't cut through the edges you can cut them in the middle, or shorten them if you need to. I think you can cut holes with a punch through them also. I think I'd do it that way and only cut three holes left right and center for the hog rings to go through. Or, you might just do the area behind the listing.
mhernandez 11-08-2011 02:43 PM
seat heaters
I cannot imagine the advantages of a seat heater. I sit on the seat, in five minutes the cold is gone from it and I keep on driving.
slodat 11-08-2011 02:54 PM
I have had several requests for them.
Dan, they are the carbon fiber heaters.
ogre 11-08-2011 04:11 PM
another texan? seat heaters are very popular up here in the north. 5 minutes in michigan isn't enough time to scrape your windshield...
