Seat help-1939 bolt? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2005, 02:43 PM
BobbyG-39's Avatar
Designer, Artist, HotRodder
I have decided to tear out and re-upholster the seats on my 1939 Ford Panel Delivery. The seats are the original, yet they're in pretty bad shape upholstery-wise. I removed the passenger seat and all its upholstery, and have removed most of the burlap/horsehair padding.
Prior the getting the seats sandblasted, I assume I will need to disassemble the seat back from the seat bottom. However, the bolt that holds it them together is puzzling . I am not sure how to remove it. The seatback pivots on this bolt, yet neither the outer dome bolt, the inner washer, or the inner bolt move. I would assume this setup is common to Fords of this period. Can anyone tell me how to remove them? Should they just slide out, or what? Thank You.
ID:	4665   Click image for larger version
ID:	4666   Click image for larger version
Old 04-20-2005, 10:32 AM
ZipZ28's Avatar
Nitrous Junkie
Last journal entry: Reflooring The Bed Pt. 2
In the first picture it looks like it's just there for a hinge point to me. If it's a shoulder type bolt it may be made for the nut and washer to tighten to the shoulder of the bolt itself,, I'd put a wrench on it and see what happens (or leave it and paint away!)
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Bolt Strength Question jamnut Engine 16 03-30-2005 07:11 AM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
