Seat mounting for racing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2010, 02:51 PM
truckboy61's Avatar
I trying to find the best way to raise the racing seats in my 61 Chevy c10? Truck came with them installed and they do not have brand logo on them to search for optional brackets. I was told to use wood blocks? I want to make sure they will pass inspection a raceway !
Old 03-08-2010, 03:37 PM
JeffB's Avatar
Wood won't pass,best way is weld square tubing to the floor and mount the seat to it with grade 8 bolts.
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You will need to fabricate some new steel seat risers and bolt them in accordance with race rules in order to pass..
Moving to basics..
Sam
Old 03-08-2010, 05:44 PM
boatbob2
Seat mounts.
Hi,when i mounted the seats in my truck,i used 1 1/2 inch square tubing,with a piece of 1/4 inch plate welded to it.,with a grade 8 bolt,placed thru the plate (with the head inside tubing,)i tack welded the head good,drilled a hole in floor and mounted it.at opposite end of tubing (under seat) i drilled and tapped a hole to put a bolt thru seat,screwed into plate.remember,measure a bunch of times,only cut tubing 1 time.
Old 03-08-2010, 09:06 PM
truckboy61's Avatar
Thanks guys for info I 'll give it a shot
Old 03-08-2010, 09:23 PM
icsmannn's Avatar
Seat Brackets
I have attached a couple of pictures of some brackets that I welded up for my "racing buckets" that have gone into my 1990 1/2 Ton Chevy LowRider. Then, if the other file loaded too, I built some "end cap sheet metal covers" to hide the gaping 1 1/2" tubing holes.
L8R Man
Icsmannn
Old 03-08-2010, 11:34 PM
truckboy61's Avatar
Thanks for the photo I gives me a good foundation to work toward , am going to print it out and get some made for my truck. Thanks again
Old 03-09-2010, 09:47 AM
icsmannn's Avatar
Yeah, you're welcome. They're actually pretty basic and very simple, once you lay out your mounting locations,. etc.....I realize my other pic didn't load as it was too big for the site to handle. If you want to see what the "end cap sheet metal cover" looks like, you'll have to send me an e-mail to "CrankShaftmcc@att.net" and I'll send them to you.
L8R
Icsmannn
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Corvette Seat Cover Replacement DanTwoLakes Interior 7 03-29-2009 01:19 PM
69 Camaro front seat mounting information needed... camaro freak Interior 2 03-17-2008 11:21 AM
Power Seat Switch Mounting 60tbirdrick Interior 5 11-30-2007 07:37 PM
Seat mounting NEVER easy daimon1054 Interior 6 12-10-2004 02:42 PM
