Seat Pad Construction for Bomber Seats - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2012, 04:32 PM
454ChevelleMalibu's Avatar
So now I need to make some backing boards for the seat bottom & back pads. My upholstery guy asked me to come up with something good and stiff. I think this is so his padding and cover work wont shift or look bad after they're installed, which I can certainly understand. The problem is I cant decide what to use. We talked about using 3/8 to 1/2 plywood. I'm worried that with plywood that thick that it will be almost impossible to bend, even if you soak it in water for awhile. He mentioned I could also use aluminum to make the panels.
The seat backs have a gentle curve to fit your back. The bottoms are mainly flat but they do kick up quite a bit right at your thigh.
So what would a suitable matrial be? Needs to be stiff. Right now I'm leaning towards the aluminum panels. I can get the stuff from work (paid for of course)so that's not a problem.
Does anyone have any suggestions for material or how to work it into the shapes/curves I need.
Thanks
Jim
Old 04-10-2012, 09:52 PM
crsweet91's Avatar
Maybe ABS plastic? I use it for all my panels. Its super tough, easy to cut and you can mold it to your seat profile with a heat gun.
Old 04-11-2012, 11:05 AM
DanTwoLakes's Avatar
Wiki Edits: 22
PVC foamboard (expanded PVC) can be heated and bent at lower temperatures than ABS, and it's also way less expensive than ABS. A 4' by 8' sheet of 6MM pvc foamboard is about $60 from a sheet plastic supplier. You can cut it with standard woodworking tools, and it can be stapled to. It's also lighter weight. I would think 1/4" (6MM) thick would be plenty.
Here's some 3MM PVC foamboard formed with heat and used as a headliner. CLICK HERE
need bomber style seat plans lowROLLERchevy Interior 13 06-16-2009 08:47 AM
Need bomber seat plans Welderman9143 Interior 2 01-21-2008 07:56 PM
Need plans for bomber seats Welderman9143 Introduce Yourself 1 12-27-2007 04:31 PM
bomber seats dgumoe Interior 2 06-24-2007 06:20 PM
Modern seat construction DanTwoLakes Interior 2 06-20-2007 01:34 PM
