Seat risers.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2010, 03:55 PM
Last journal entry: comming along
Seat risers..
I bought new seats for my 37 Ford. They came from a 99 Chevy Cavalier. Problem is.. I sat in it when I set it in the car, and I can see straight threw the steering wheel. I need to raise the seats 4". I have seen the Langdon seat risers, but $98.00 is a little steep. Can I make them?? I need to go up 3 1/2 to 4" straight up. The slant is already built into the riser that is bolted to the seat. I set one of the seats on two pieces of 4x4, and it worked ok. I could still go up another 1", or 1/2". Would it be bad to place a piece of 12 gauge plate on top of a 4x4, and run a bolt straight threw the steel plate, threw the 4x4 wood, and threw the floor and the mounting plate I have under there now?? Thanks.. Al
Old 11-16-2010, 05:28 PM
Irelands child's Avatar
Speedway has some that you could make work. I used their sliders and made up my own risers
http://www.speedwaymotors.com/Univer...unts,2432.html
Being made up
Installed in the car
If the local steel shop had the right size 'C' channel in stock the day I picked the steel up, would have used that instead of the rectangular tubing - the risers got heavy!!!!
Dave W
Irelands child
Old 11-22-2010, 07:32 PM
pnt4u2's Avatar
seat riser
I had the same problem. I found the remedy at a fence supply store. I purchased 2- 4" x 4" x 6' fence post. These are made of heavy gauge aluminum. I cut them to fit and used them to install a 60/40 rear bench seat and I am now installing front power buckets seats in my truck. I paid $20 for each post. They were some left overs from another job they had. Hope that helps.
Old 11-23-2010, 02:45 PM
I found some 2x2 steel conduit. I was able to cut 8 6" pieces. They work great in the front, but I may have to go up another inch in the rear. Al
Old 11-23-2010, 03:50 PM
daoldbuick's Avatar
You could check out the risers used on the front seat of vans. The ones in my 04 caravan would be about that height. Sometimes parts from one seat can be used under something else. With a little massaging. I put the power unit from a tbird bucket seat under the bench seat from a caravan, works great.
Old 11-23-2010, 04:05 PM
The seats I had in the front were from a newer Chevy van. I'll have to measure it. It would look better than the conduit.. Al
Re-Padding an Old Car Seat...Part Two DanTwoLakes Interior 3 09-24-2010 02:11 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Corvette Seat Cover Replacement DanTwoLakes Interior 7 03-29-2009 01:19 PM
seat risers??? 49fordp/u Interior 2 12-12-2007 02:59 PM
Power Seat Wiring Info Needed- Mid 70's Chevrolet/Chevelle LongTom Electrical 1 02-06-2007 01:36 PM
