seat swap for 1955 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2004, 07:38 PM
i was just wondering if there were any bench seats with a fold down console that would fit in my truck that have the same bolt pattern. i have a 55 chevy 2nd series pickup.
Old 01-28-2004, 07:07 AM
Wiki Edits: 49
Not sure about the second series but for the 47-55 first a late 70's or early 80's Olds Tornado split bench will fit and has the fold down console. I don't think the bolt pattern is the same and you'll probably have to fab up a mount but it should fit even better in the second series trucks since they are a tad wider.
Centerline
Old 01-28-2004, 07:23 AM
Custom User Text:
A 1997 Full size chevy seat will fit in a 1958 truck.
Old 01-28-2004, 03:31 PM
do i have to make a mount with that 97 full size seat
Old 01-28-2004, 04:36 PM
Custom User Text:
We got the seat with the Factory risers on it. I think you have to space up the middle. But, that is a 60/40. On a bench I think it should set right in.
Old 01-29-2004, 05:27 PM
did you set up the electronics on it
Old 01-30-2004, 09:47 AM
Thom Laybourne's Avatar
12 Volt Lead
Just a 12 Volt lead wire. Use the frame for ground. I have the same truck and I am looking for a new seat also. If you can, please post a photo of what ever you end up with. I have just finished doing the power brake under the floor and am starting to move the gas tank to the rear frame. I hope to make a small electronics drawer to fit under the seat for the sound system. Keep me posted.
hr41pearl
