Seat Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2007, 06:11 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Seat Wiring
I picked up a set of bucket seats from a Jeep Cherokee. Does anyone know about wiring these things up? I found the wires for the drive motors ( up-down etc.). All the motors work. The drivers side front-back motor says MEMORY on the motor itself and has 3 more wires than the passenger side. The drivers side front-back motor only moves in 1 direction.
Old 02-25-2007, 10:12 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
There should be (2) wires in each motor for the power. Reversing the power at these wires will change the direction of motor rotation.
The (3) additional wires are for memory feedback. These wires will not be
required.
If the motor won't run by reversing the power wires it is likely jammed at the limit of travel.
vicrod
Old 02-25-2007, 10:23 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
So I may have a problem with the switch. I have the tracks off as I'm working on getting them fit into my truck , so its deviantly not from binding up.
Also, the "MEMORY" motor should work OK with just the seat switches?
Anything I should know about the heater wiring? How do I check these?
Each seat has a red and black which operate the motors.
I have a Red/Black and a Lt Bl/Wh left over.I take it these would be for the heaters?
The drivers side has 2 extra wires at the harness. Must be for the memory. Sound about right?
Thanks, Pugsy
Old 02-25-2007, 10:55 AM
vicrod's Avatar
life is a ride
The memory motor should work OK without the (3) feedback wires connected.
As shown on the attached diagrams.
The seat heaters probably will need a control box as these heaters are thermostatically controlled and have at least (2) heat settings.
I suggest you get the shop manual for the donor car for more detail on the controller. Or subscribe the www.alldatadiy.com.
The red and black wires would be for power and ground to feed the seat control switch.
The remaining wires are likely for the heaters. Power and temp. control.
vicrod
File Type: zip 1999 Jeep Truck Grand Cherokee seats - System Diagram.zip (273.4 KB, 115 views)
Old 02-25-2007, 12:28 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks alot.I'll see what I can figure out with all these drawings.
The donor vehicle is not available for parts. The guy I got the seats from had only the seats.
Pugsy
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Power Seat Wiring Info Needed- Mid 70's Chevrolet/Chevelle LongTom Electrical 1 02-06-2007 02:36 PM
Power seat wiring old41racer Electrical 3 02-17-2006 04:33 PM
GM Power Seat Wiring Ronhel Electrical 2 03-02-2004 08:49 AM
Power Seat Wiring Mr Bob Electrical 6 12-29-2003 03:56 PM
