seat wrinkles - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2010, 10:25 AM
seat wrinkles
i scratch built this seat a couple months back. 3/4 thick plywood, 5 in wirecut 2560 foam rave material both red and black. i glued the center panels to 1/4 thick sewfoam with weldwood landau adhesive. now i have wrinkles toward the back and i can't tell if it is the rave turning loose from the sew foam or between the sewfoam and the high density foam. the panels are not glued to the high density only stretched and stapled. what do you think is happening?
Name:	46 truck seat.jpg
ID:	48895   Click image for larger version
Name:	46 truck seat2.jpg
ID:	48896   Click image for larger version
Name:	46 truck seat 3.jpg
Old 10-14-2010, 11:04 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Let the seats sit out in the sun on a nice warm day, and then sit on them.
You probably used too much glue to hold the fabric to the sew foam. You only need enough glue to hold the fabric to the sew foam long enough to stitch around the perimeter of the parts, the lighter the better. I don't use contact adhesive to glue fabric to sew foam, I use foam to foam glue that I know won't hold when the seats get warm.
Nice looking seats.
Old 10-14-2010, 11:08 AM
thanks, what name brand foam to foam glue do you use. i'll try it
Old 10-14-2010, 11:15 AM
Wiki Edits: 22
I use products called Kwik-Spray 225, K-Grip 201, or K-Spray, and spray them with a Critter Sprayer. Check out this Wiki article on contact adhesives. CLICK HERE
Re-Padding an Old Car Seat...Part Two DanTwoLakes Interior 3 09-24-2010 02:11 PM
60's Mustang Seat Upholstery DanTwoLakes Interior 10 08-16-2010 12:55 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Corvette Seat Cover Replacement DanTwoLakes Interior 7 03-29-2009 01:19 PM
Power Seat Wiring Info Needed- Mid 70's Chevrolet/Chevelle LongTom Electrical 1 02-06-2007 01:36 PM
