seats for 32 ford 3W coupe
Okay, I've got my roller(glass body) sitting in my garage on jackstands. The engine is done, the tranny is done although not installed yet. The rear end is in. What next? I haven't cut the holes for the brake and clutch pedals since I can't get the nerve up to do it. So I thought I would go ahead and get the seats in so I could better determine where the placement of the pedals should be as well as the steering column. I thought about using either Honda or Acura leather buckets. Question is, will they fit. Are there any others that would work better other than going the aftermarket route and the big bucks. Also thanks to those of you who helped me out on the hydraulic clutch questions I had. Ended up going with a hydraulic throwout bearing. Not going to be racing this puppy so it should work well and really made things simple.
Tom |
We used front buckets out of a 94 Honda Accord in the 32 3W we just got on the road. The driver's seat is all power except the lumbar support adjustment.
The passenger seat is manual. Both seats, leather covered, plus seatbelts cost us $135 at teh junkyard. The fit is a little tight, as in touching in the middle, and the seat adjustment controls are very tight to the door panel, as in touching. In a different world we would have taken the seats to a trimmer and had the inside bolster of each one narrowed and the cover reinstalled. This would have allowed a tighter fit inside. But...it rides great and how many times do you ever adjust the seat after you're in it anyway?? |
Thanks for the info. I figured the Honda seats would be a snug fit. Glad to know it'll work though. What did you do for door panels?
We haven't gotten the door panels made yet, or rather, upholstered yet. The panels are made from upholstery board(the black waterproof cardboard) and have been trimmed and drilled for clips and handle, etc. clearance and access.
We are looking at armrests now and have to make up some or use some from an old car (we have some 46-48 Plymouths, 36 Oldsmobiles and a couple others to try). Don't forget to install a sheet plastic water barrier on the inside of the door before you install your door panels. The factory doesn't do this for giggles, they do it to protect the door panels, yet most custom upholsterers do not use them, used to showcars which never see weather I guess. |
If your not set on buckets I used a middle seat out of a 93 Dodge Caravan. It is about 40 inches wide and fit perfectly.
32 ford 3w
I am looking to put a bench seat in my 32 Ford 3 w. How does the caravan seat fit in your 32? Can you send me a picture of how it looks in your car?
Thanks Terry |
This is the center seat out of a '91 Chrysler Minivan. It fits my 3 window perfectly with just enough room on each side to reach down and grab the seat belt (about 3" clearance between the seat and the door). Its like it was made for it. In an "A" this seat will be a little tight but still fit with no problems.
Thanks for the info and the picture. Looks great in the car. I will go shopping today for one..
seats
Hi Tyeager55 The seats Centerline posted look exactly like mine with the same fit. Hope it works for you
| Recent Interior posts with photos |
| Building a 1932 5 Window Ford Coupe | 32FordVA | Introduce Yourself | 3 | 01-28-2006 04:38 PM |
| 36 Ford Coupe Advice | dhinrichs47 | Hotrodding Basics | 8 | 01-25-2006 08:02 AM |
| 1930 ford 5-window coupe | flatsider48mc | Introduce Yourself | 3 | 12-07-2005 02:27 PM |
| My 35 ford coupe | gunnulf | General Rodding Tech | 7 | 11-03-2005 10:55 AM |
| 33 Ford hiboy 3 window coupe | gypsy | Body - Exterior | 2 | 03-11-2003 08:03 AM |
