Second gen f body steering I'd help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2013, 07:19 PM
Thommyknocker's Avatar
LOLLERS
Last journal entry: Th2004r 1-2 accumulator
Ive got a second gen f body subframe under my 50 Chevy (done by the previous owner)
T
It also has a 1975 Pontiac firebird 350 engine in it, from the same car?
It needs a center link, but the one I think I need (6" outer tie rod end length) is $200
The camaro one is $38 lol
From my research it appears I can change out all the tie rods and center link to camaro parts and be way cheaper.
Can anyone verify that for me?
Old 06-19-2013, 08:47 PM
kso's Avatar
kso kso is offline
Can't exactly verify it but I like to look at the RockAuto site for comparisons like that. The Moog part for Camaros (DS829)is $40 and the Firebird (DS883) is a bit over $90...if you're to believe the pictures (at your own risk, they may be merely "representative"), the Firebird has a wider oil pan clearance "dip" in the middle. I'm guessing the Pontiac motor has a wider pan? If so, using the Camaro part would result in the center link hitting the pan with the steering cranked over.
Or, it's possible, the Firebird was designed with a tighter turning radius (to help sell the slightly-more-expensive version of the F-body) and it needed the wider dip for that reason...in which case, who cares.
In either event, the worst thing that might happen by using the Camaro unit is that you'd have to weld a little material on the steering stop so it hits that before the pan. Perhaps you could get the Camaro part and install it loose real carefully, check it out, and swap it for a 'Bird part if you have to but not if you don't.
Old 06-20-2013, 08:34 AM
LOLLERS
I got a little more info from digging around.
The difference was probably for the Pontiac fuel pump. Low on the drivers side, so they lowered the pitman arm, different center link for clearance.
I'm not using the mechanical pump, and I've moved the engine back and up.
I'll try just the Camaro center link first, and if the inner tie rods look weird I'll get them as well.
I've got a pitman arm that is flatter, and looks like the pic in this link
Idler and Pitman Arms are different lengths!?! [Archive] - NastyZ28.com
So I'll try it as well.
Thanks for the help.
First-Gen F-body Guldstrand modification dave_letu Suspension - Brakes - Steering 3 06-19-2006 04:33 PM
3rd Gen F-body rear discs on 65 A-body 12 bolt? smallblocker2 Suspension - Brakes - Steering 7 03-22-2006 12:51 AM
dropping a 1st gen f-body joefromcocomo Suspension - Brakes - Steering 2 08-17-2005 06:19 PM
Wheels for 3rd Gen F-Body tpilews Suspension - Brakes - Steering 0 03-20-2003 02:14 PM
2nd Gen F-body rdk409 Hotrodders' Lounge 7 01-09-2003 06:47 PM
