Edelbrock describes the secondary operation like this:
A mechanical secondary air velocity valve in Performer Series carbs senses air-flow according to demand and automatically regulates a smooth transition from part throttle to wide-open throttle. These carbs have mechanical secondary throttles that should open wide when you rotate the linkage all the way. |
i agree with double.. isnt it a vac secondary ?
*edit* on a holley vac sec wont open just revving the engine in neutral. there has to be a load. the secondary idle enrichment comes from the amount of transfer slot showing in the secondaries. on a stockish engine i use boxes. the slot is as long as is wide... or .020 whatever it sez. on a mild or hot build i like a box and a half. Last edited by spinn; 06-20-2006 at 09:12 AM. Reason: holley example explaination |
The Holley vacuum secondary carbs have secondary butterflies that are operated by the vacuum developed in the primary venturis, the more vacuum in the venturi the farther they open. If you rotate the throttle mechanism completely, only the primary butterflies will open until the vacuum is sufficient.
The Edelbrock carbs have mechanically operated secondary butterflies, when you rotate the throttle mechanism fully, all four butterflies will open. The amount of air drawn through the secondaries is controlled by an air valve above the secondary butterflies. On the Performer series carbs the air valve has a fixed counterweight and the opening rate is not easily adjustable. On the Thunder series carbs the air valve is spring controlled and is easily adjustable. |
i guess they are not vacuum operated. thanks for the correction.
is this the one with spring rod down the center, and the doors open 80% ? i thought that was vacuum controlled.. oh well sorry for the confusion. |
I have Thunder Eldelbrock, Not a Performer, Not a Holley
hold that thought
right on , that will explain it |
http://www.edelbrock.com/automotive/..._features.html If you read closely you will see the statement that I copied for my earlier reply. If your secondaries don't open fully when you rotate the throttle linkage to its limit, you should investigate the linkage for a problem. |
I'm wondering if you are confusing the air valve butterflies that are above the secondary plate with the secondary plate. You shouldn't be able to see the secondaries unless the air valve is opened. If you are seeing the secondary air valve butterflies only partially open, that is normal. Much like a Holley, it won't open fully unless under load. If you manually hold the air valve open so you can see the secondaries, you can open the throttle fully to see if they are operating correctly(engine off,of course). It is highly unlikely that the secondaries are only opening the little amount you are seeing, it would have been caught at the factory. I suspect you are perceiving the air valve as the secondaries.
Got is fixed! The linkage for the secondaries on the side of the carb had a tiny screw wedged between the linkage and the carb that were keeping the secondaries from opening all the way. A small black screw, no telling where it came from but now the secondaries open all the way under full open throttle. Thanks to all that tried to help with this. Problem solved!
| Holley 650 / Edelbrock performer combo | Andy in SD | Engine | 4 | 11-07-2005 09:25 AM |
| edelbrock thunder carb | 79transam | Engine | 5 | 11-21-2003 09:34 AM |
| Edelbrock Thunder Series carb | kaddylowrider | Engine | 1 | 11-06-2003 02:09 AM |
| Edelbrock 1904 secondaries question | rakundig | Engine | 3 | 10-29-2003 07:56 PM |
| Edelbrock Qudarjet secondaries | 56wagon | Engine | 7 | 05-17-2002 04:46 AM |
