Secondary leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2006, 08:57 AM
PHATHOM's Avatar
My wife said no more hotrods..
Secondary leak
Ok, after some helpful advise from my previous post "351w Fast idle", I have confirmed it is due to secondaries not sealing completely. I know I can swap base plates (I have a spare), but is there a way to salvage this one? Is there an adjustment I am looking over? The reason is this one has been reman'd and plated to look perfect and I would hate to offset that.
Old 05-04-2006, 10:30 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Make the platers aren't bent or warped out of shape. Make sure the secondary shaft is centered correctly and check for grooves in the hole where the secondary plates rest.
Old 05-04-2006, 06:33 PM
i just recently had similar problems with my carb. secondaries hanging open. i took the secondary shaft out and cleaned it up with light emery cloth. it was also slightly bent. seems to be moving freely now. took me 45mins to an hour. might be worth a try to swap secondary shafts only.
good luck,
keith
Bad Oil Leak,,, Help! Lthompson Engine 8 08-15-2007 03:33 PM
Q-jet vacum leak? montea Engine 5 04-20-2006 09:31 AM
Need help finding a light oil leak! frankenvette Engine 5 05-26-2004 05:45 PM
it was a cack leak 302truck Engine 1 01-11-2004 11:27 PM
Power steering leak! fireschenie Suspension - Brakes - Steering 3 03-09-2003 04:39 PM
