secondary plate to metering block converssion help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-24-2008, 10:45 PM
tubbedz's Avatar
Carb body#4
If you made it this far, pat yourself on the back, you're almost done. Now we can move onto the Carburetor body. You will need to drill through the bottom of the carb body so that you intersect the mixture screw channels in the metering plate. See attached pics, these are drilled at right angle intersections. Do not go too deep, you only want to intersect the channel already there. STUDY THE ATTACHED PICS, very carefully. Understand what you are attempting to do before you drill. Then study the pics some more until you are confident enough to drill.
Name:	metering block1.jpg
ID:	35183   Click image for larger version
Name:	metering block 1a.jpg
ID:	35184   Click image for larger version
Name:	metering block2.jpg
ID:	35185   Click image for larger version
Name:	metering block 2a.jpg
  #17 (permalink)
Old 12-24-2008, 11:02 PM
tubbedz's Avatar
Power valve plug #5
If you are confident of your work, you are basically done. You will need to run a power valve plug in this metering block as I did not describe how to modify your carb for a secondary power valve. Maybe in another "thread" I will. At times, you will need to change/adjust the vac secondary metering spring opening rate as vac secondary carbs do not have a secondary squirter.
You will need to clean the carburetor passages very well as there will be a ton of aluminum shavings all over the place. The shavings may even clog the idle mixture screws. If you think it's clean....guess what, clean the passages again.
Like I said at the beginning of this thread, I will not or am not responsible for anything that you did or will do to your carburetor to perform this modification. I'm simply helping my fellow hot rodders out with a simple example of a 4-corner idle mod. If this mod fails for you, I'm sorry. Go back and study the pics or buy yourself a Holley book and read. I have done this several times before and had never had an issue on my carbs. I'm not a Holley expert, just the average Hot Rodder that knows my carbs real well and am often asked to tune Holley designed carbs.
Good Luck and Merry Christmas!!!!
Which chevy block to start with? Midlife Crisis Engine 11 01-19-2009 06:45 PM
holley metering block won't adjust 59 f-100 Engine 2 09-11-2008 04:54 AM
small block vs big block JUSTINH Engine 28 02-17-2003 04:37 PM
Torque Plate Hone TurboS10 Engine 12 12-28-2002 03:13 PM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 07:06 AM
