secondary plate to metering block converssion help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2008, 11:57 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
is it possible to bolt on the rear of a 4160 a front metering block instead of the metering plate?
I know there are kits to make this conversion but I have 2 spare primary blocks.
I guess I would have to plug the power valve passages and possibly the idle mixture circuits as well.
Am I right?
thanks
Augusto
Old 12-23-2008, 12:22 PM
King of my Man-cave.
You needn't plug anything up. If the baseplate is drilled for the vacuum source for the power valve, you can use one there also. If it is not drillled, you can drill it for use with the power valve, or you can leave it and use a power valve plug. Or, just use a power valve plug in any case. Otherwise, there is nothing else to do. You will need to use jets that are appropriate in size.
tom
Old 12-23-2008, 12:44 PM
Augusto's Avatar
thankx Tom,
how about the idle mixture screws?
Augusto.
Old 12-23-2008, 01:02 PM
Just screw them in all the way.
tom
Old 12-23-2008, 01:50 PM
tubbedz's Avatar
If I remember correctly, I performed this in the past on a Holley 1850-4 (4160-style) 600cfm vac secondary. If you are doing this conversion to create a 4-corner idle system, you will need to modify the idle passage in the base plate and drill the carb body. If this is not done, the mixture screws may need to be screwed all the way in and have no real function. Pick up this book: Holley Carburetors (S-a Design) (Paperback) by Dave Emanuel (Author). This book will tell you the proper way to do it. Also once your carburetor is modified, you may or may not notice a little stumble when the secondaries kick in as their is no secondary squirter on a vacuum secondary carb. If you can't find the book I can post pics on the modification for everyone.
Old 12-23-2008, 06:51 PM
Augusto's Avatar
please post the pics because it will be very hard to find the book in this lands.
thanks.
Augusto.
Old 12-23-2008, 06:53 PM
Augusto's Avatar
Originally Posted by F-BIRD'88
You can also modify the holley secondary metering plate to accept standard screw in Holley main jets. You need a 1/4" -32 thread tap.
where should I drill and tap the plate? can you post a pic of it, sounds like a lot easier.
thanks
Augusto.
Old 12-23-2008, 08:53 PM
Augusto's Avatar
Thanks a lot man, this is a very good advise and pretty easy to do, I preffer to drill and tap so I can change the jets according to what's needed.
this sealall stuff looks quite good, I hope it is available down here I'm gonna look for it.
Merry Christmas
Have a great holiday.
Augusto.
Old 12-24-2008, 01:12 AM
tubbedz's Avatar
Augusto, I hope you're not in a rush. I will post the 4-corner idle modification and pics/diagrams in a couple of days as I need to dig up the old books from storage.
Its a simple mod that converts a vac sec carb to give you two more idle screws to fiddle with. Tubbedz
Old 12-24-2008, 11:08 AM
Augusto's Avatar
I'll wait, thanks a lot,
I appreciate your concern
Augusto
Old 12-24-2008, 05:21 PM
Augusto's Avatar
it's a generic 1850, 600 cfm, vac sec.
no problem about machining the plate I have a full machine shop, the only tool I don't have and I really wish I had is a bridgeport mill, someday I'll treat myself.
Augusto.
Old 12-24-2008, 10:10 PM
tubbedz's Avatar
How to 4-corner idle your Holley
Augusto, here it is, I will try to be as thorough as possible.
The following is how to modify your Holley carb so that you can have a 4-corner idle carb. This is assuming you are installing a secondary metering block with idle screws already installed. I will separate the mod into two sections. First, the throttle plate and second, the carb body.
I am in no way responsible for any errors that you or anyone have caused when this modification is done to your carburetor. I have performed this procedure many times and am not responsible if you are new, an expert, or an amateur and performed the procedure wrongly. If you do not understand, buy a Holley carburetor book. All the Holley books describe this modification.
Old 12-24-2008, 10:16 PM
tubbedz's Avatar
Throttle Plate #1
You will need to block the interconnecting fuel transfer track in the throttle plate. There are two tracks. You can fill it with a fuel resistant epoxy, like JB weld or you can block the slotted track with a steel plug or shot. What this does is seperate the track into two, the primary and the secondary.
Name:	fill channel1.jpg
ID:	35175   Click image for larger version
Name:	fill channel2.jpg
Old 12-24-2008, 10:21 PM
tubbedz's Avatar
Throttle plate #2
Now you must fill the small hole below the fuel transfer slot in both secondary bores. You may or may not have these holes, if you do...fill em. It is the constant-feed idle discharge hole.
Name:	plug tiny hole1.jpg
ID:	35177   Click image for larger version
Name:	plug tiny hole2.jpg
Old 12-24-2008, 10:32 PM
tubbedz's Avatar
Throttle plate #3
Now comes the drilling. I forgot the bit size but these are very small hand held drill bits. You must drill this in the exact angle as the "red arrows" in the attached pictures. This drilled hole must intersect the vertical hole in the main body. Study the attached pics before you drill, as this is crucial and if done wrong, throw the plate away. Always think, measure twice, then when absolutely sure.......measure and think again, then finally take a chance and drill. If you make a mistake here, your throttle plate is rubbish.
Name:	drill angle1.jpg
ID:	35179   Click image for larger version
Name:	drill angle2.jpg
ID:	35180   Click image for larger version
Name:	drill angle1a.jpg
ID:	35181   Click image for larger version
Name:	drill angle2a.jpg
Which chevy block to start with? Midlife Crisis Engine 11 01-19-2009 06:45 PM
holley metering block won't adjust 59 f-100 Engine 2 09-11-2008 04:54 AM
small block vs big block JUSTINH Engine 28 02-17-2003 04:37 PM
Torque Plate Hone TurboS10 Engine 12 12-28-2002 03:13 PM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 07:06 AM
