Secondary spring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2007, 10:27 PM
Getting distracted at work...
When I stomp on my throttle, my engine bogs; almost shuts off. I read in a magazine where a guy wrote in with the same stuff I had (a C-3 with a Demon carb) and was having the same problem. The magazine said its the secondary springs in the carb. I got the spring kit the group of different springs, and I can't remember what the mag said about the stiffness and the secondary opening. The chart that came with the springs makes it seem that the soft the spring, the sooner the secondaries will open. But I "thought" I remembered it being the need for a stiffer spring that was causing the problem. Someone please set me straight...
Hammer
Old 12-01-2007, 10:34 PM
you talking about vacuum secondary? a stiffer spring will open the secondaries slower and a softer spring will open them faster. if it bogs real bad off the line try a step or two stiffer, but you may have a prob with accel pump size and shot size, just keep playing but only make one small change at a time, and maybe document the changes and how it ran. to see what you like the best. good luck.
learning carbs is a whole lot easier than learning women, thats why men love cars.
Old 12-01-2007, 10:40 PM
It not bogging from too much gas... When I stomp on it, its almost like the engine dies for a second, then...takes off. The mag said it was from the butterflies opening faster than the secondaries were shooting gas. So the delay was from a big pocket of air..Know what I'm sayin?
Hammer
Old 12-02-2007, 12:06 AM
bog
I think is your pump arm. The spring will not cause a bog that bad. It will just seem sluggish till 3000 rpm. Lightest (open sooner) yellow, purple, plain (standard Holley) black (will probably not open all the way). Try the black if that helps you know that is it. If that does not help try the pump arm spring tighten it one turn try then keep going. If it backfires then loosen. It should be preloaded to just touching depending on your setup Ie high stall. Might check your timing as long as the hood is up.
A- body spring question gilliganspl Suspension - Brakes - Steering 2 03-11-2007 09:44 PM
Spring clamp question. HemmiGremmie Suspension - Brakes - Steering 2 05-10-2006 04:56 AM
Leaf Spring Question 39chevy Suspension - Brakes - Steering 2 11-19-2003 05:35 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
secondary spring 69 chevelle SS Engine 2 09-11-2003 05:50 PM
