The secrets of rust removal part II - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2005, 09:46 PM
Last journal entry: Shift boot...
Not too long ago there was a thread on rust removal.Im in the process of replacing the windshield on one of my cars.Once I got all the trim off the car I found a few spots of rust in the windshield frame,some pretty bad.Some like to grind,media blast,convert the rust but I always use Navel Jelly or acid to remove it.In the past ive used battery acid to dissolve the rust but this time I used Navel Jelly.This stuff must have a shelf life,the bottle ive had for a year didnt work so I went and got a new bottle,worked like a charm.The secret to removing the rust with this acid is you have to keep the area wet................
Old 11-03-2005, 09:47 PM
roger1's Avatar
Nice job.
What did you treat the pinch-weld with after your rust removal?
I recently went thru this process with my '69 Vette and used epoxy primer.
Old 11-04-2005, 09:30 AM
Originally Posted by roger1
Nice job.
Once I was finished stripping the windshield frame of all paint and rust I seam sealed all joints,primed with some Dupont DTM epoxy primer amd them shot a few coats of SEM trim black.ive got to repaint the trim and im done......Really like that midyear ya got there,one of my all time favorites is a 66 Coupe,Mossport Green,small block.
Old 11-04-2005, 09:34 AM
One of these days ill paint it,not anytime soon........................
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
what were they thinking? Part II goose Hotrodders' Lounge 9 02-20-2004 03:31 PM
Y'all be good boys n gals PART II - Pac Northwest Style 68Impala Hotrodders' Lounge 0 12-16-2003 08:40 PM
Rust removal 35 chevy Body - Exterior 1 10-30-2002 08:24 PM
HR.com, $$ and you (Part II) Madd Syntst Hotrodders' Lounge 48 08-18-2002 03:11 PM
