Securing Oil Pickup to Oil Pump - Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2008, 01:59 PM
72NOVA454
Securing Oil Pickup Tube to Oil Pump - Help
well it happened - the impossible.........
my oil pickup tube/screen thingy fell off the oil pump while I was driving. I shut her down immediately and saved the world.
It's a Chevy V8 - big block. Stock type M77 oil pump, stock type oil pan, stock type pickup. I pressed in a new pickup into a new oil pump. Perfect installation - very tight - but it fell off after only 20 miles of driving for whatever reason.
Now I gotta pull the whole motor again and redo it.
Question: what is the best way to secure that thing on there. I've heard of welding, brazing, and a retainer strap.
what is the easiest and cheapest method that will work?
thanks
Lee
Old 04-30-2008, 02:47 PM
Guy Hiltz's Avatar
Lee,get it tack welded by someone that has a MIG welder.I use a Moroso pickup that can be bolted in place,and I also got it tack welded.Check this link.
http://www.moroso.com/catalog/catego...?catcode=12002
Mine is the one in the middle,I have a small spacer between the bracket that bolts to the pump body and the pump body itself.It's not going to fall off !!!
Guy
Old 04-30-2008, 02:55 PM
72NOVA454
Guy
I've got a MIG welder - just wasnt sure if that weld would be good. The pump body is iron and the tube is thin steel - thought it might burn a hole in the tube if my welding is bad.
So you are saying that that Moroso pickup you've got bolts to the pump housing? I'll take a closer look at it and the pump.
Lee
Old 04-30-2008, 02:58 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
I also use the meiling or moroso pump and pickup combinations that bolt to the housing. I feel most confident with this setup.
Welding to cast iron pump housing is not always the best idea and vibration are just as likely to break a weak weld as they are to shake a tight pressed pickup loose. I have used epoxy to hold it in for sure and that works well too.
But nothing works as well as a good old fashioned bolt.
Old 04-30-2008, 03:07 PM
72NOVA454
I agree with what you say - makes sense. It may last for a while but after enough heat cycles and vibrations the weld may go bad - it's possible since the 2 materials are different.
sounds like I need to get one with a securing strap that bolts.
Old 04-30-2008, 03:10 PM
justold's Avatar
If you are afraid to weld it , drill a 1/8 hole through it and install a cotter pin in it .
Old 04-30-2008, 03:15 PM
72NOVA454
interesting idea but I don't think I'll do that. are you talking about drilling through the oil pump housing and pickup tube? that would probably work but may weaken the housing. I'll try to get one of those bolt on types that get secured to the pump housing or something else. I may weld it also just for good measure.
those things are not cheap. I was just looking at Summit - looks like $40 or more.
Lee
Old 04-30-2008, 04:29 PM
Guy Hiltz's Avatar
My old pump had the pick up welded to it for many years and the weld was still as good as the day it was put on.
Guy
Old 04-30-2008, 05:40 PM
Marcel
Last journal entry: Choo-choo town
oil pickup tube
I might weld it, cause I don't think there would be that much vibration in the oil.
I different would not drill a hole thought the pump and tube housing for a carter pin. I would be afraid it'd suck air instead of oil, especially when cold. I give $40. to keep from putting the pan. I mean oil, filter , gasket (that'd be about $40. buck)besides the time and work.
Old 04-30-2008, 06:44 PM
72NOVA454
Originally Posted by F-BIRD'88
You can get the oil pan off a BBC in a Nova. You'll need to jack the motor up, off the motor mounts.
Unbolt the headers from the exhaust and engine. Remove the spark plugs. Remove the distributor cap. May have to remove the fan or the top of the fan shroud. Remove the engine mount thru bolts and loosen or remove the trans mount bolt. Jack the motor up with a floor jack and block of wood on the oil pan and support the jacked up motor with wooden blocks wedged under the motor mounts so you can remove the jack and get the oil pan off and back on. May have to remove the starter.
Lay a good tack weld bead with the mig welder on the pickup tube. It will hold.
hey F-bird - hows it going bud - havent chatted in a while.
I think you are right about doing this by just jacking up the the motor, but I decided to pull the whole fricking thing. I was under the car lastnight looking at it. I "might" be able to lift the motor/trans enough to get the pan out of there but it will be tight. I'm just going to attach a lift plate to the manifold and pull the entire motor/trans at once.
this sucks big time.
Lee
Old 05-01-2008, 05:56 PM
I'd braze it if you have access to a acetelene/oxygen rig. Lower heat than a weld. Braze will flow like solder. Clean everything and use brazing flux.
Old 05-01-2008, 08:15 PM
72NOVA454
there is a welding guy around here I called. He said bring it to him. I'll see what he says when he looks at it.
I agree that brazing or possibly TIG weld would be best for that application.
Old 05-01-2008, 09:08 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Weld it on or weld a strap onto the pickup and bolt it on the pump.
Old 05-01-2008, 09:22 PM
junior stocker's Avatar
pickup tube.
Moroso and Milodon both have pickup tubes that have an additional bracket to secure it to the oil pump housing. The only big block I ever owned had the pickup tube secured with a lenth of coathanger wire wrapped around the tube and bolted down in 2 places. Not pretty, but it worked; I replaced it with a Milodon piece when I rebuilt the engine. I've never had one fall off, and I've never had one welded on.I prefer to use the Moroso/Milodon units.
Old 05-07-2008, 01:52 AM
I brazed mine and it stayed on until I crash-landed the pan on a big rock in Arkansas. Stupid rock.
Be sure you take the pressure relief spring out before you heat the pump.
Be sure you put it back in afterwards.
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 06:26 PM
Small Block Mopar oil pump priming. Hippie Engine 2 12-30-2007 04:53 PM
Lean backfire Camaro76 Engine 5 04-15-2003 06:45 PM
oil pump drive shaft. christopher406 Engine 7 01-30-2003 06:42 PM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
