Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Seeking Advice: Installing Fuel Pump & Fuel Lines
  #33 (permalink)
Old 04-02-2011, 02:26 AM
35terraplane's Avatar
35terraplane 35terraplane is offline
fuel pump fuel line
Originally Posted by horvath
Thanks to everyone.
I ran the fuel line inside the frame rail and then ran about 9 feet of 1/2-inch plumbing insulation (the black foam stuff) over the fuel line. Nice protection!
I also installed the new fuel pump and everything went very well. No leaks. Job well done, I'm happy to say!
Now I'm thinking about adding a Fram HPG1 Performance Fuel filter back by the fuel tank, before the fuel pump. See here:
http://www.amazon.com/FRAM-HPG1-High.../dp/B000CBSFSQ
Is that the correct type of filter for me to use (before the fuel pump)?
Alan
Alan you can use that filter, again if it is going to be on the frame or below the tank you will either have to put a ball valve, or shut off on the line between tank and filter, unless you want to take a gas bath.
Bob
