Thanks to everyone.
I ran the fuel line inside the frame rail and then ran about 9 feet of 1/2-inch plumbing insulation (the black foam stuff) over the fuel line. Nice protection! I also installed the new fuel pump and everything went very well. No leaks. Job well done, I'm happy to say! Now I'm thinking about adding a Fram HPG1 Performance Fuel filter back by the fuel tank, before the fuel pump. See here: http://www.amazon.com/FRAM-HPG1-High.../dp/B000CBSFSQ Is that the correct type of filter for me to use (before the fuel pump)? Alan |
I like using armored steel tubing. The spring wrapping protects the steel line from abrasion, and also makes bending it much easier, as the spring stops the tubing from kinking. You can buy this tubing in 6" to 72" lengths from Papco-Paulin ... and I am sure many other manufacturers as well. Here is a link to a PDF catalog that contains many different products ... including some nylon tubing solutions. Ridgid tools also offers a reusable spring type bending tool. |
fuel pump fuel line
Bob |
Bob: Forgive me, but I don't even know what a ball valve is. I want to add this filter though, so I'm just gonna be sure to keep the lines that go in and out of the filter *above* the fuel level of the tank.
66GMC: Thanks for the info about the armored steel tubing. Alan |
![]() You'll probably want a 3/8" one. |
Horvath,
do you have any pics of the fuel line installed? What type of clamps did you use along the frame? I'll be doing this soon on my truck. thanks, James |
Hey, James.
I didn't take any pics. I ran my 3/8" steel fuel line on the inside of the frame rail ... then I slid foam rubber insulation over it, sold at Home Depot for 1/2" water pipes (4 4-foot lengths for 2 bucks!) ... and secured the fuel line at both ends only, using vinyl clips screwed to the frame and a couple of vinyl ties in the center areas. It worked out really great! The foam rubber is really thick and covers the fuel line the entire length of my frame rail. PS: I taped the end of the fuel line before sliding it through the frame rail to be sure I didn't scoop any dirt into it. Alan |
Thanks
My pleasure, Brother.
PS: When I get the time, I plan on replacing the vinyl fuel line clamps with these neoprene cushioned aluminum clamps: A box of 10 costs $5 and can be purchased Here Alan |
Yep, got some of those clips in different sizes...guess I'll drill holes and bolt them on....with my luck, screws would gouge me when I'm under there for other work
| need some friendly advice, fuel pump fuse problem | untchable502 | Engine | 1 | 12-10-2010 08:13 PM |
| Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines | J.J. LASALLE | General Rodding Tech | 6 | 06-29-2009 01:04 AM |
| fuel pump/ fuel lines | bad apple | Engine | 2 | 03-12-2009 10:43 PM |
| Need advice on fuel pump selection. | 67 Deuce 4 Me | Engine | 4 | 01-08-2005 09:34 AM |
| BG Pump, Fuel Cell Braided Lines | 68NovaSS | Engine | 9 | 10-14-2004 10:25 AM |
