Seeking Input on Cable Operated Clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2013, 03:51 PM
I have a space problem that might best be addressed by using a cable to operate the clutch. I hope someone can steer me to a source of a suitable cable -- I can fabricate the firewall and transmission brackets so a suitable cable is the only issue ( 1.25" travel, 125 pounds pull force, and the ability to operate through a 180 degree bend at 8" radius) -- The clutch to be operated is early 90's Chevy SB truck . There are several reasons why neither hydraulic or mechanical linkages are attractive.
Thanks for any help and HAPPY HOLIDAYS!
Old 11-29-2013, 04:24 PM
RWENUTS's Avatar
Try here!
Control Cables, Inc.
The Following User Says Thank You to RWENUTS For This Useful Post:
v123 (11-29-2013)
Old 11-29-2013, 11:48 PM
The suggested link is a great tip -- This company has a great product range and the required technical information -- I'll find out Monday about their pricing - LOL
Old 11-30-2013, 04:59 AM
poncho62's Avatar
Wiki Edits: 5
Fox Mustangs used a clutch cable....63" long
The Following User Says Thank You to poncho62 For This Useful Post:
v123 (11-30-2013)
Old 11-30-2013, 08:49 AM
Fang16's Avatar
Last journal entry: Project change
Back in the day I rigged up a buddy's 37 Chevy coupe with 327, 4sp with two adjustable pullys and a lenght of 1/4 aircarft cable. His brake n clutch were floor mounted. Worked like a charm.
The Following User Says Thank You to Fang16 For This Useful Post:
v123 (11-30-2013)
Old 11-30-2013, 10:04 AM
Thanks for the Fox suggestion, undoubtedly will hit my pocket more softly than a custom made cable -- Also, those old floor mounted pedals had many advantages, pity they were given up. If this clutch were a floor mount the solution would be simple
Old 11-30-2013, 11:23 AM
RWENUTS's Avatar
So what's holding you back!
Make it a floor mount connection.
This sight is not called hotrodders for nothing.
techinspector1 (11-30-2013)
Old 11-30-2013, 12:49 PM
Northstar T's Avatar
Gone sailing
The cable is easy enough. as others have said, use aircraft cable and some nico-press sleeves to make up your own end loops. I used a cable clutch on my T bucket and it works very smooth. several cars came with cable clutches, and can be a good source of parts. I started with a Corvair pedal assembly, which saved me a lot of work fabricating a firewall mounted setup. by using this as a base to work from, you'll also get the brake pedal and master cylinder mounting as a bonus. I'm using a Blazer bellhousing, which came as a cable setup as well, to adapt to my T-5 trans.
It's not a system you see every day, but it really does work out well for many applications. good luck with it.
Russ
The Following User Says Thank You to Northstar T For This Useful Post:
v123 (11-30-2013)
Old 11-30-2013, 05:18 PM
Thanks to all, I'll post a picture when I get it (hopefully) working
4l60e input clutch housing question? old yukon Transmission - Rearend 7 02-03-2011 09:43 AM
removing the clutch hub of the reverse input drum old yukon Transmission - Rearend 4 02-01-2011 10:37 PM
aluminum firewall thoughts (seeking input) toolman1967 Body - Exterior 6 03-12-2008 06:46 PM
cable clutch on gm t5 pats 5speed ss Transmission - Rearend 8 01-05-2007 05:55 PM
Clutch cable djdans50s Transmission - Rearend 3 09-28-2006 09:51 AM
