Seeking Timing Computer Recommendations - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 11-16-2012, 07:07 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
Anybody running a relatively simple timing computer that they're happy with?
I would like to lock out the timing on my HEI distributor and do all the spark advance with some kind of box that I can program a simple 'curve' into. Being able to hook up the vacuum advance to it too would be a real bonus.
Current setup is a SBC HEI with MSD module & matching coil - which I am impressed with, BTW.
Thanks
Russ
Old 11-16-2012, 07:28 PM
Banned User
You might want to even consider electromotive's direct ignition system.
Simple, but not cheap, but worth it.
Old 11-17-2012, 05:53 AM
gearheadslife's Avatar
MentalMuffinMan
I have a nice msd unit..
you might look into a MEGASQUIRT not sure.. but I'd guess you can use it as an ign. timing box only..(they have a forum ,so you could get all your answers)
it's cheap.. and you can set the tables to whatever you want.. with a lap top..
and if you ever deside to go efi you already have the box..
Old 11-18-2012, 01:37 PM
mustang 671's Avatar
i run omex ecu. has an amazing amount of tecky stuff . have a look at my threads of it and it shows some screeen shots ,it may be more involed than what want and also the cost ,
worth a look
Recent Modern Electronic Engines posts with photos
recommendations for distributor timing revspan Hotrodding Basics 10 09-27-2012 08:29 PM
383 ignition timing recommendations? v8hed Engine 11 05-21-2010 03:39 AM
Does anyone have a wiring diagram for a Mallory #600 timing advance computer...? Bumpstick Electrical 3 04-07-2007 11:52 PM
Seeking MIG welder recommendations Slipangle Garage - Tools 6 10-20-2004 09:04 PM
computer controlled timing propaniac Engine 7 06-10-2004 07:31 AM
