Seized Bolt in Engine Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 02:49 PM
64Joker's Avatar
64Joker
I'm attempting to remove a bolt on a 327 engine (1964 GM) located the side of the block. I've tried the strong arm approach, but no luck.
I've reviewed a few of the other posts regarding this issue but they were not directed related to an engine block.
Some of the suggestions are listed below, should I apply these same
techniques to bolds mounted on the engine block? I presume the heat of the oils/engine seized the bolt.
Thanks in advance...
1. heat up bolt, cool down, reheat, cool down, attempt to remove bolt.
2. easy out
3. PB blaster
4. Aerokroi
Old 06-13-2010, 05:13 PM
32Essex's Avatar
Is the engine in a car ? Is the bolt head broken off ? Can you get to it easily to clean around the threads or is it holding something to the block ?
Old 06-13-2010, 05:14 PM
327NUT's Avatar
Double post, already answered...
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Engine Dies When Distributor Bolt Is Loosened? HotRodMan Engine 10 11-30-2006 12:34 PM
Noisy valvetrain leading to seized engine? biggeazy-e Engine 6 11-22-2006 11:15 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
