Seized Bolt in Engine Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 02:50 PM
64Joker's Avatar
64Joker
I'm attempting to remove a bolt on a 327 engine (1964 GM) located on the side of the block. I've tried the strong arm approach, but no luck.
I've reviewed a few of the other posts regarding this issue but they were not directed related to an engine block.
Some of the suggestions are listed below, should I apply these same
techniques to bolds mounted on the engine block? I presume the heat of the oils/engine seized the bolt.
Thanks in advance...
1. heat up bolt, cool down, reheat, cool down, attempt to remove bolt.
2. easy out
3. PB blaster
4. Aerokroi
Old 06-13-2010, 02:51 PM
ericnova72's Avatar
More for Less Racer
Where exactly is the bolt located?? Size of bolt??
Old 06-13-2010, 04:07 PM
64Joker's Avatar
64Joker
The bolt is located about 1" above the oil pan, center of block, driver's side.
I'm using a 9/16 socket to remove, the bold has not been stripped.
I need to use the hole to insert an after-market Dakota Digital oil pressure sender unit! Its the best spot on the block to support the device!
Old 06-13-2010, 05:01 PM
406 bug's Avatar
9.82 @ 139mph
The only thing behind that hole is water.
Old 06-13-2010, 05:04 PM
ericnova72's Avatar
More for Less Racer
Yep, only thing there is water.
Old 06-13-2010, 05:08 PM
327NUT's Avatar
The bolt at the location you're describing go's into the water jacket. It is used to drain coolant from the block. Sometimes a petcock is installed there to make it easier. Is there a bolt at the same location on the other side of the block? ooops, eric beat me to it....
406 bug's Avatar
9.82 @ 139mph
The one you want is just above the oil filter. This is usually a plug with a recessed socket head. Very difficult to remove. I have had excellent results with Proto screw extractor #9525 3/8 " - no heat required.
Old 06-13-2010, 08:35 PM
64Joker's Avatar
64Joker
Follow-up
OK, I located another possible bold at the front on the engine right below the intake (Please See Pic), bolt is circled in green! Will this work for oil pressure reading??? Thanks....
Old 06-13-2010, 08:47 PM
406 bug's Avatar
9.82 @ 139mph
NO. Original sending location (next to disrb.) or the one mentioned in my previous post- THATS IT.
Old 06-13-2010, 09:00 PM
ericnova72's Avatar
More for Less Racer
Yes, that plug leads to the main oil galley, you can read pressure there. That hole is only present on blocks made prior to about 1973 or so IIRC, it is not on all blocks.
Old 06-13-2010, 09:59 PM
64Joker's Avatar
64Joker
Plug Removed
Ericnova72,
You are correct! The bolt was easy to remove and indeed was covered with oil! Whoo Hoo! Thanks a million.....
Old 06-13-2010, 10:22 PM
64joker,
Just to set the record straight. What you removed is a pipe plug not a bolt.
1/8 pipe plug.
Scholman
Old 06-14-2010, 08:46 AM
406 bug's Avatar
9.82 @ 139mph
Ericnova72,
Sorry for the misinformation, Eric is right on!!!
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Engine Dies When Distributor Bolt Is Loosened? HotRodMan Engine 10 11-30-2006 12:34 PM
Noisy valvetrain leading to seized engine? biggeazy-e Engine 6 11-22-2006 11:15 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
