Seized Cyclinder Head Bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2011, 12:04 PM
SEIZED CYCLNDER HEAD BOLT
cyclinder head gasket blown.Engine still to ticking over with slight miss. Removed head but found some bolts seized. Wd 40 does not help as i cannot soak bolts. Is there a way this can be loosened without damaging aluminium head. thanks
tnana.
Old 10-05-2011, 05:19 PM
327NUT's Avatar
Are the bolts seized in the alum. head or the alum. block? If it's the block the bolts are probably "galled" which means that the threads are locked into the alum block material and they are a beoch to get out. You can use a torch to heat the block but obviously you have to be VERY careful with how much heat is applied....just enough to loosen the bolt......trail and error and of course keeping your fingers crossed. Then use a good anti-seize lube when putting it back together
Old 10-05-2011, 05:20 PM
tnana.
Which bolts are seized? How did the head come off with seized bolts?
Bogie
Old 10-05-2011, 05:46 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Bogie
X2. I've never seen a head come off with a bolt still thru it.
Seized flat head 6 Jmooner Engine 3 10-18-2009 02:27 PM
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
head bolts jrm123180 Engine 1 07-31-2004 11:00 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 04:50 PM
engine seized, t-converter bolts? dadeeoo Engine 2 05-23-2003 09:30 AM
