Select Head Gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2011, 02:44 PM
Select Head Gasket
Talking about a original iron block with ProFiler aluminum heads with 11.20:1 static compression and Total Seal rings. Block is 3/4 filled with Hard Blok.
I was using a composite type head gasket before with "461" iron heads. The block was decked two years ago and has a good smooth surface. Will I be wise to switch to a MLS gasket because of the brand new aluminum heads. Of course, I had no problems before, with the iron heads.
I would prefer to use the same Mr.Gasket 5800 composite as before because of the perfectly sized valve pockets in that gasket.
Thanks in advance.
Joe
Old 12-10-2011, 02:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I see no problem w/using the same p/n 5800 head gasket. I have not used them, just going by the published info.
Unable to separate head from block due to head gasket sealer Nostalgia Hotrodding Basics 18 02-02-2011 01:12 PM
head gasket clwarters Engine 3 04-28-2010 12:16 AM
cracked head or head gasket???? onebadmerc Engine 12 12-04-2008 12:10 PM
head gasket ?? neverfastenuff Engine 2 10-23-2008 09:32 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 04:50 PM
