Selectable Supercharger?!? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2005, 08:24 PM
nissan rodder's Avatar
Nissan v. Mustang... Any bets?
Just an idea for about any vehicle.
Has anyone ever seen a Supercharger setup where it used an A/C style elctromagnetic pulley. Just a thought but wouldn't this allow you to be able to pass Smog (remeber, I live in California) and still have crazy horsepower at the flip of a switch?
Would be pretty cool, if it would work. Anyone know the answer to this one?
Thanks,
N_Rodder
Old 04-04-2005, 06:54 AM
daimon1054's Avatar
There are many 50 state legal supercharger systems out there. My problem also is a supercharger is a pump and it does not bypass air very well when it is not turning so you would have almost no power when you turned it off.
Old 04-04-2005, 07:48 AM
Ah, Ok, didn't think about that.
thanks
N_Rodder
Old 04-09-2005, 07:15 PM
Last journal entry: frame build
Just had this discussion on the hamb forum. It can be done and has been done but the common thought was why. A blower uses little power when not needed and in fact the airflow through it helps drive it at low demand. The manifold pressure will go to vaccum at low rpm. So, the consensus was why add the extra weight and complexity.
Old 04-10-2005, 02:34 PM
Big Blocks Rock's Avatar
New Member
So you can look real cool like Mad Max.
Old 04-12-2005, 07:06 PM
Docs91RS's Avatar
Isnt that what nitrous is for?....horsepower at the flip of a switch....hmmmmmm
Old 04-12-2005, 07:41 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
The Chrysler Crossfire SRT6 has one, I'm not sure how it works but the engine/blower is from the Benz parts bin.
Old 04-13-2005, 08:59 PM
mitmaks's Avatar
Last journal entry: Grille
ive seen what they call them "clutched supercharger" for imports, works pretty good
Old 04-14-2005, 02:46 PM
Rhansen's Avatar
Footbraker
The one I saw was setup to only engage at WOT. The lifespan of the clutch was directly related to how often you hit WOT.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Age old question. Turbo Vs. Supercharger Andyrew Engine 78 08-19-2005 07:35 AM
will a paxton SN93 supercharger fit my 351w? Fordy8man Engine 2 04-03-2005 12:00 AM
Possible/worth it? 3.8L supercharger on 305 chevy Project87c10 Engine 9 12-20-2004 07:44 PM
supercharger problem mad van Engine 1 06-23-2002 10:42 AM
