Self Etching primer vs. epoxy primer - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 06-08-2009, 01:33 PM
brainsboy's Avatar
brains
Originally Posted by 52F1
Here we go again Your advise is Wrong
We are her to help people.... not give out a Ludicris opinion with NO foundation whatsoever.
52F1
Maybe you should read posts more clearly.
First of all I didnt give out a ludicris opinion. My original post said to use CAUTION not that it couldnt be done, you need to be careful with the products your choosing.
I have ran the PPG SV epoxy primers over USB filler with problems. I called PPG and they said themselves that epoxy primers should be used on bare metal only and other people have complained about the same issues we had. As the PPG tech also pointed out even though it may work over other fillers and primers epoxy primers are chemically designed for metal. Sealers however work better over other products.
  #47 (permalink)
Old 06-08-2009, 02:30 PM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by ssaahemifan
I had trouble using SPI Epoxy and metal prep even though I scuffed the treated surface before epoxy.
I have always metal prepped every car I do. This was the first time using SPI epoxy and I had some adhesion issues.
I was going to abandon it for a different epoxy that is compatible with metal treatments ??
Maybe I don't have to???
SPI says no etch products.
Ahh,metal prep,what kind?I use SPI epoxy exclusively and always prep so your problem must be in the "metal prep".read the ingrediants does it say water anywhere?If you want to know what I use ,Pm me, I'll show you a great way to do it that I've learned in my 35 yrs of P&B. even got pics to help ya
  #48 (permalink)
Old 06-08-2009, 07:17 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
What is PPG SV epoxy? The only SV I could find was an Omni product that specifically allowed filler as a substrate. Could you please provide a link to the tech sheet? I'm always ready to learn! Thanks!
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Self Etching or Epoxy Primer Ron M Body - Exterior 14 11-30-2010 06:23 AM
epoxy or etching primer 35prog Body - Exterior 15 08-07-2007 06:33 PM
epoxy or etching primer over bare metal? pineknot Body - Exterior 21 03-16-2007 07:53 PM
Epoxy Primer / Etching Primer olds37dude Body - Exterior 3 01-27-2005 04:25 PM
