SEM Hotrod black "grit in it when sprayed" - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2011, 08:18 PM
cyclopsblown34's Avatar
Colorsanding painter
The HOK satin black my paint guy sold my buddy exhibits the signs of old reducer, it is in fact SEM hotrod black in kit form a quart of black, 8 ounces of reducer and eight ounces of catalyst. The first coat I sprayed had the grittiness you get when using old reducer. The second coat, I used Nason medium urethane reducer, same story. Third try, SEM paint, Nason medium reducer and Nason ful thane hardener, same story. I know the Nason is good because it is what I used this weekend with the flattening compound fiasco that resulted in a flawless finish but too shiny, it did dull/flatten eventually but I don't think I can repeat those results as far as sheen. This has all been done on similarly prepared square gallon cans from reducer and SPI clear. Is it Iso clumping causing the problem with the SEM? Each application was on a different can. I did mix up Nason black and throw in some flattening compound just for grins and it sprayed out smooth and we'll see if it flattens.
Man,that's one long old paragraph.
Sorry about the rambling paragraph,
Chip.
Old 04-20-2011, 11:48 PM
milo's Avatar
point on positive
The Sem should be thinned with a lacquer thinner not reducer unless your in California and then they say a"SR" reducer to be VOC compliant.
mabe try some good lacquer thiner and thin it about as thin as water(17 seconds#2 Zahn cup) and see how a test panel turns out..
Old 04-21-2011, 05:06 AM
BarryK's Avatar
If you used a urethane reducer in this (right or wrong) that did not cause the grit.
I THINK this stuff is an enamel base, IF I'm right then you have a seedy activator (bad)
Urethane activators will not cause a seed as they just get weak and don't dry right, enamel activators will seed. (kinda a good warning system)
Old 04-21-2011, 05:08 AM
Thanks Milo, this is the SEM HR010 kit, it was sold to my buddy as House of Kolor, I was kinda let down and my opinion was tainted when I saw the brand name. This thing has Spies base and SPI clear, to me SEM is on par with Nason or Kirker. I'm going to check with SEM today since all three items are labeled with lot numbers. We may end up just trying to either mix the Nason single stage black with flattening agent or see if somebody can find me a code for GM underhood black and get that mixed in single stage urethane.
Old 04-21-2011, 05:26 AM
BarryK's Avatar
One other thing that can cause this but rare, is if the product froze in the past and now you have a pigment kick out.
The pigment will not strain out through normal strainers and you can not mix them back in without heating to 175 degrees and using a high speed disperser.
Rare but does happen.
Old 04-21-2011, 05:29 AM
BarryK's Avatar
Black epoxy??????
Old 04-21-2011, 05:33 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Barry, does that paint have a flattener in it?
Can that be the culprit?
Old 04-21-2011, 05:35 AM
BarryK's Avatar
Unlikely as the flattener if out of suspension or to high air pressure will show white snow flakes.
Old 04-21-2011, 06:37 AM
Barry, your epoxy is what I suggested and when I sprayed it, he thought it too flat. He's trying to replicate the black he has underhood and it is a satin black. I'm thinking about suggesting underhood black and be done with it. It'll definitely be a SS urethane and not enamel.
Old 04-21-2011, 07:04 AM
milo's Avatar
point on positive
I used the SEM Trim Black from a aresol can on the Duster hood in this thread..
SEM HotRod Black opinions
The mix in the spray cans is laucqer as well as in the quart cans but mabe thats the difference between the "Hot Rod Black" and "Satin Trim Black" formulas ..
*use a good respirator with either of these,,. theres something extra bad in there in this reporters opinion
Old 04-21-2011, 07:13 AM
are you just dead set on using a ss with flattener? there are good mat clears out there....sikkens/lesonal has one and ppg has one...i'm sure the other guys do.
attatched pic is just one nice wet coat of the sikkens mat clear......2 coats with proper flash will give a little more gloss than in the pic.
Thanks Milo, I wear a respirator, even when cleaning my guns or mixing paint. we may end up using an aerosol SEM trim black.
Old 04-21-2011, 07:15 AM
Jeremy, I wasn't even giving that a thought, thanks for the idea. I'll contact my paint guy and see if DuPont offers a matte clear. If not, I'll contact my PPG guy.
Old 04-21-2011, 07:57 AM
with the sikkens you can also cocktail it with any of their clears to give more gloss......which works better, i think, than any pure flattening agent...atleast with this system.
you arent going to get a purely FLAT finish with this system.
Old 04-23-2011, 12:29 AM
deadbodyman's Avatar
Wiki Edits: 11
Why not get the paint code for a challenger....they can look it up at the paint store ,this way you can use ANY brand you want...
What do you think of the (flat) "hot rod black" paint appearing on new supercars etc. Ripped General Rodding Tech 5 07-30-2010 07:33 PM
What's "relative grit" of scotchbrite gray pad cboy Body - Exterior 9 06-14-2008 06:57 AM
What ever happened to black "waterproof" cardboard door panel material? pasadenahotrod Interior 9 01-23-2007 01:59 PM
Show me some "satin black" paint jobs Blackdog Body - Exterior 4 02-25-2006 01:17 PM
anybody sprayed "as cast" paint on an intake? bullheimer Engine 7 04-28-2004 09:03 PM
