SEM HotRod Black opinions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2011, 01:05 AM
BMM BMM is offline
Hey guys. Well, I just picked up an 82 Cutlass. It's certanley not in the budget or timeline to do a nice bare metal, excellent quality job on the body right now (saving to move east a bit). Anyways, I'm considering a quick sand and nailing it with some satin black. SEM Hotrod black I can get a gallon with reducer and hardner here for 80 bucks right now.
Anyone have experience with this stuff? Hows it spray, hold up against washes etc, any tiger stripping? It only needs to last a few years at most until I strip her right down.
Cheers!
Old 02-03-2011, 02:20 AM
milo's Avatar
point on positive
SEM trim/hotrod black is an excellent choice..
Easy to spray wisping on the final coats to control even coverage/sheen. Thins with lauqer thiner..
Needs no primer , will protect as well as sand off easy later acting as a guide coat...
Will last 10 years in straight sun,and if it does show any wear
just scuff and recoat..
**Must use a quality mask when spraying, don't breath this stuff
Old 02-03-2011, 06:08 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Sem products are first rate in my book...
Sam
Old 02-03-2011, 10:01 PM
BMM BMM is offline
Good news. Thanks guys. Milo, by whisp do you mean something like with a metallic single stage or more like a drop coat for base?
Old 02-04-2011, 02:14 PM
milo's Avatar
point on positive
Yes, like spraying a base color..You will find you have a lot of control with time between coats to sweep off any overspray or dust nibs with a piece of scothbrite or 400 sandpaper.. Plan on several light coats instead of piling it on..
Again bad to breath be sure and use a mask..
Pictures too..don't forget to get some pictures
Sem hotrod black 71broncrollsport Body - Exterior 1 10-25-2010 04:38 PM
hotrod black comparison? runn141 Body - Exterior 3 05-30-2008 09:04 PM
another hotrod black ? runn141 Body - Exterior 1 01-13-2008 11:29 PM
hotrod black sanding racer2312001 Body - Exterior 6 09-23-2007 07:07 PM
hotrod black sanding racer2312001 Introduce Yourself 1 09-23-2007 07:46 AM
