sem rust-mort - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2008, 12:19 PM
theccrider's Avatar
always proceed, go forward
sem rust-mort
I'm using this stuff for the first time, mostly on floors and light surface rust, and was wondering if there is any precautions you guys would suggest prior to paint.
Old 07-24-2008, 12:48 PM
Yes use this stuff as a rust REMOVER and not as a "converter". If you use it to remove the rust, and it works quite well for that, and then remove the residue you should have no problems. No matter what any product claims DO NOT PAINT OVER RUST!
Old 07-24-2008, 01:14 PM
theccrider's Avatar
how would you "remove" the rust that is in the pits, such as an old frame when using this stuff.
Old 07-24-2008, 02:19 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I use a spot blast to get the pits out..first I hit the easy areas with my sanders before I start blasting..saves on blast media that way..On the Rust Mort SEM will tell you in the tech manual to get ALL THE RESIDUE off prior to painting..Even using SEM paint such as rust shield which is a decent product for interiors and such..We use it on tractors and equipment..
Sam
Old 07-24-2008, 03:18 PM
theccrider's Avatar
Thanks guys, but one more, what if you have already primed over some of this stuff? sand and start again????
Old 07-25-2008, 12:58 AM
Sand blast any rust pits, you don't need rust returning in a year or two. I like Dupont metal prep and thier two part bare metal Vari prime paint. The last two cars I have used DTM primer. Epoxy is tough but harder to sand. Also the compressed air for the paint gun needs to be dry and clean.
Rust inbetween Double Seem Questions Advice on ATTACK Plan fcastro Body - Exterior 3 01-22-2008 12:20 AM
Rust Spots WildBill Body - Exterior 3 11-09-2007 07:22 AM
need help on wiki article: pitted rust Jon Body - Exterior 4 08-07-2007 10:38 AM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 06:48 PM
Rust Converter - SEM Rob the blob Body - Exterior 1 06-26-2003 10:13 PM
