Semi Flat Clear Coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2010, 06:28 AM
WHo has a good semi gloss, satin or flat clear to put over a DuPont or nason base coat. The one I used last night was DuPont clear with some flex additive in it. This is the mix given me by my paint jobber. Worked OK. Last time I used a Hot-Rod flat type of clear and it worked good, but the paint store does not handle it anymore.
Any other advice?
Old 11-10-2010, 10:48 AM
TucsonJay's Avatar
PPG makes a flattener designed to be mixed into clear paints. It has mixing ratios on the can for different types of finish. I have used it in RM clear with no problems. The "full flat" mix is the most even finish. The "semigloss" tends to be shinier in areas that get sprayed "wetter"... like in corners.
Not sure... but I think the number is "DX468"???
Old 11-10-2010, 10:49 AM
4speed's Avatar
Ohio Firebird Member
Last journal entry: 77 TransAm W72
I used the PPG Deltron red oxide paint w/flat clear under my car to make it look correct.
Old 11-10-2010, 11:59 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
SPI has a flattening agent for their clears..when using a flattening agent it is good to shoot a test sample to make sure the finish meets your desires..
Sam
Clear Coat Adhesion Problems Jaymez Body - Exterior 31 09-23-2010 09:34 AM
What is the Most Super Glossy Clear Coat? jeetkunedoground Body - Exterior 29 06-07-2010 10:25 AM
Newbie Painter Queston, Spraying Clearcoat Which way is Best jeetkunedoground Body - Exterior 10 06-03-2010 10:25 PM
What clear coat and how to for polished aluminum 1964 Oldsmobile 442 Body - Exterior 13 06-03-2010 08:52 PM
Clear Coat Problems Help!!! coupe33 Body - Exterior 4 01-01-2008 07:55 AM
