seperating pistons from the rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2010, 01:38 PM
hello,
im tearing apart an old 350 i just got and i cant figure out how to get the pistons and rods apart. do i just need a little more elbow greese or is it something i have to take to a shop?
thanks
Old 07-05-2010, 02:15 PM
DoubleVision's Avatar
They press on and off. This is best left to a shop to perform. They are pressed off with a high tonnage press and placed back on with the rod heated in a oven to expand it. The shop also makes sure the piston orientation is correct on the rod. I also hope you numbered the rods upon removal. If not you`ll have to ask the shop to orientate them for you upon reassembly.
Old 07-05-2010, 02:18 PM
Wiki Edits: 31
machine shop.
Old 07-05-2010, 02:23 PM
327NUT's Avatar
machine shop
Old 07-06-2010, 08:18 PM
texas97z's Avatar
Last journal entry: A little progress and maybe new paint
Hack saw, matches, and an apple. Wait, what are we talking about?
Old 07-06-2010, 08:29 PM
If you don't plan on re-using the pistons and you have access to a hydraulic press, you can press them out cold. If I knew I'd be boring-out the block, I'd do as much as possible to keep labor costs down at the machine shop. Luckily the place I worked at, had a press to use. As mentioned earlier, hopefully you marked the rods/caps and main caps, before removing them.
Are all chevy 5.7 rods the same? Warrant Engine 21 01-23-2011 11:35 AM
5.565 or 5.7 rods? JohnyR17 Engine 9 10-09-2010 07:17 PM
Pistons DoubleVision Engine 7 11-23-2009 12:10 PM
Lightweight rods, pistons, balancing & valve gear DENCOUCH Engine 14 10-23-2009 02:01 PM
LT1 Pistons & Rods Chev37 Engine 4 12-17-2001 10:32 PM
