Is this sequence correct? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2005, 09:05 PM
napier's Avatar
I plan on painting my first car soon and I made a list of the steps in which to do things and i would just like to have someone make sure they are correct. Well here goes
1. Sand and fix dents with filler
2. Apply epoxy primer and scuff
3. Apply primer ( what is the sandable kind?) sand the car
4. Use a guidecoat where dents were fixed and sand as needed
5. apply sealer
6. apply basecoat/cc
7. cut and buff
Thanks guys i just want a list to go buy so i cand do all the stages correctly
Old 02-10-2005, 11:50 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Basically correct. Do a search on the topic on this board. It has been covered in great detail. Would probably require 20 or 30 pages of posts to duplicate the info.
Old 02-11-2005, 05:38 AM
Will you be stripping this car to bare metal or just painting over the existing finish?
Old 02-11-2005, 06:01 AM
Wiki Edits: 49
I suggest you read the "Basics of Basics" series of posts at the top of the body exterior forum. These were written by a very experienced custom body and paint professional and should answer most if not all your questions.
In short you have pretty much everything in the correct order. However, if you are going to strip the car to bare metal you should use the epoxy primer first before repairing the dents with filler. The filler will stick to the scuffed epoxy just fine and the epoxy will protect fhe bare metal from rusting.
Centerline
Old 02-11-2005, 07:38 AM
napier's Avatar
I dont plan on sanding it to the bare metal as its in preety decent shape as is, I do plan on sanding one rear quarter to the metal as the paint is peeling. Thanks for th reply's guys im gonna just look around and read up thanks alot though
