Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Serial no. for old Chevy truck engine
Old 01-21-2013, 02:06 PM
killeratrod's Avatar
killeratrod killeratrod is offline
I found noting with those numbers also, check buy the dizzy or take the valve cover off and check the head numbers out. this may help you get a closer idea of what you have.. also check the oil pan for 235 this will stand out on the pan, as you might not have a 216.
