series 1,2,3,4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2005, 08:39 PM
todel1223's Avatar
series 1,2,3,4
I have been reading some post and see you talk about series 1,2,3. What are these?
Old 09-11-2005, 08:55 PM
poncho62's Avatar
Wiki Edits: 5
havn't a clue........never saw it.........what is a todel1223?
Possibly, series 2, 3, 4 gear carriers?
The gear carriers are different depths to accomidate the different thicknesses of crown gears.
Old 09-11-2005, 11:31 PM
Higher (numerically) gear ratios generally have a smaller-diameter pinion gear. The carriers that are compatible with higher-ratio gears will have the ring gear flange farther to the right, closer to the centerline of the pinion gear. That way they don't have to use a thicker ring gear.
Different rear end designs will have different break-points for their respective carrier series's. In other words, one might use one series for 2.73 & up ratios, while another will use one series for 3.08 & above, but a different series for 2.73 and below.
Old 09-12-2005, 08:55 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Some ring & pinion gears are also machined to fit a carrier series that they would have NOT normally been originally been able to be intsalled on.
If you have a series 2 carrier normally meant to carry a gear set of less than 3.08, a set of these 3.73 or 4.10 gears machined to physically fit a series 2 carrier WILL fit, but a standard set found in a donor car in the local junkyard would not as those are machined to only fit a series 3 carrier.
HTH.
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 09:27 AM
gm 10 bolt series I.d. tkett32 Transmission - Rearend 6 07-03-2005 08:16 PM
Super 40 vs 50 Series Delta Flow dannimo Engine 3 01-27-2004 04:16 PM
Super 40 or 50 Series DF dannimo Engine 0 01-19-2004 10:25 PM
54 chevy ? pichoboxing Hotrodders' Lounge 11 07-29-2002 07:32 PM
