Series II 3800 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2004, 06:30 PM
Scuzzy's Avatar
Certified Cruck Lover
Series II 3800
Does anyone know if the FWD series II 3800 has the same trans bolt pattern as the old buick 3.8 litre motors? I'm curious as I think that would make a neat power plant in a rear wheel drive config (especially with the factory supercharger)
Old 06-15-2004, 06:41 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I think we had a post on this subject a couple months back.
Surf back a page at a time and see what you come up with.
You WILL find a couple things out about it you may find as being a problem.
1. bellhousing pattern matches the 2.5 L-4, 2.8 & 3.1 V-6.
2. There are NO provisions for longitudinal motor mounts, you will need to fabricate mounts to whatever places you can find to bolt them on to with this engine.
Old 06-15-2004, 11:55 PM
Scuzzy's Avatar
Thanks for the reply! I hadn't even thought about the mounts that could turn out to be a real nightmare!
