Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Serious problems removing harmonic balancer!
Old 06-03-2005, 06:26 PM
NorthStar's Avatar
NorthStar NorthStar is offline
Your description isnt very good Im totally confused.
Are you trying to pull the damper off using a jaw type puller or what?
It kind of sounds like you have all the main caps off and torqued on the thing and dislodged the crank from the bearings.
Is the engine on a stand?
