Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Serious problems removing harmonic balancer!
Old 06-03-2005, 06:03 PM
Lonestar's Avatar
Lonestar Lonestar is offline
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Get the crank back into its proper position, torque the caps down and verify that the balance is actually cocked...may be just an optical illusion.
If it is cocked, then get it back on right like Bracketeer said.
Block the crank with wood and carefully remove it with the balancer puller. You could add a little heat with a propane torch, just a little though.
