Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Serious problems removing harmonic balancer!
Old 06-03-2005, 06:27 PM
Lonestar's Avatar
Lonestar Lonestar is offline
"May the Schwartz be with you"
Last journal entry: Finally getting going...
I don't thing the balancer is holding you up at all. I think by using a 4' breaker bar and having loose caps you have that crank wedged. Try prying on the counterweights (very carefully) in the opposite direction as you cranked on the puller.
