Serious problems removing harmonic balancer!
I have the puller rigged up right, when I was using a breaker bar and 4 ft long pipe the crank came up at an angle. I was told wrong that I could untorque the main bolts before pulling the harmonic balancer. I should have followed the book.
What should I do now? The harmonic balancer is on at an angle and the crank ends up about 1/2 inch the above the block. I haven't been able get it straight by hammering the balancer either. I have no idea what to do now. btw this my first time turning a wrench. Any help is much appreciated, John |
question
Where's the timing cover? I can't see why you would need a 4 ft bar to remove a balancer. To you have a rotating cap on your puller?
Try tapping the pistons back down in their bores to get the crank back into position. Reinstall the caps. Get a balancer installation tool and try to get it back straight. |
All the pistons and rods are out of the engine?
That makes things a lot easier. The crank is just stuck now because you had caps off and torqued on it. Its wedged on the thrust I suppose. See if you can turn it back the other way it should fall back into place. When you get the caps back on there use a 2x4 block of wood between the counterweight and pan rail to keep it from rotating when youre removing the damper. Use some kind of washer on end of crank snout so it doent get damaged and make sure threads on puller are oiled up good. |
I can still spin the crank a little bit, I need a way to get the harmonic balncer in straight. thanks, JOhn Last edited by spyderdude; 06-03-2005 at 05:59 PM. |
Get the crank back into its proper position, torque the caps down and verify that the balance is actually cocked...may be just an optical illusion.
If it is cocked, then get it back on right like Bracketeer said. Block the crank with wood and carefully remove it with the balancer puller. You could add a little heat with a propane torch, just a little though. |
I can't get the crank back into the proper positon because of the balancer not being on straight, I'm positive.
What exactly is the balancer interfering with...the timing cover?
I'm not really sure honestly. I don't know how the harmonic balancer is keeping the crank from falling back into place, it doesn't make sense to me.
Bet you wont do it this way ever again.
Everybody messes up when I first started boss came and told me every time you ******* up we take a knuckle then he holds up his hand like he was missing a couple fingers. Possibly when crank tilted up in back chain side got some slack and timing chain is out of line keepng front side pulled down. If youre working on a small block Chevy take the puller off and measure how far the end of crank is from edge of damper. If damper hasnt moved at all will be about 1 inch, if its about 2" watch out for your foot its ready to fall off. Last edited by Greg Latvala; 06-03-2005 at 06:25 PM. |
Its 302 ford, it has been pulled off quite a bit, I have no idea how far it goes though.
I don't thing the balancer is holding you up at all. I think by using a 4' breaker bar and having loose caps you have that crank wedged. Try prying on the counterweights (very carefully) in the opposite direction as you cranked on the puller.
Just for a dumb qusetion on my part, but the crank bolts' washer isn't still stuck to the balancer? This is about the only thing I can Think of that would make a balancer need a 4' snipe to remove.
| 283 Harmonic Balancer | JamesD | Engine | 29 | 03-14-2007 05:36 PM |
| Harmonic Balancer Installation | DTL504 | Engine | 2 | 06-15-2004 10:17 AM |
| Removing harmonic balancer | saenz5 | Engine | 7 | 05-14-2004 06:08 PM |
| SBC 350 Crank Balancer Problems | bjam2 | Engine | 8 | 05-04-2004 07:36 PM |
| Crank Pulley / Harmonic Balancer | surfrat6 | Engine | 2 | 09-01-2003 05:33 PM |
