Serious steering problem! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2006, 08:46 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've just started driving the '68 Nova and have some serious steering issues. The entire front end is new, bushings, tie rods and ends, springs, etc, and a fresh alignment which went well.
Driving on a flat relatively smooth surface the car will make a move right or left out of the blue. If I were at highway speed I'm sure it would change lanes before I could reel it in. It's power steering and the box doesn't seem to have excessive play. One thing that concerns me is the rag joint. I've seen pictures of manual steering joints that look way sturdier than mine, mine is simply the flexible rag joint with flat pie shaped metal pieces under the bolts that turn down over the edge a small ways. seems like a sloppy and very flexible connection to the steering box shaft. I actually tore a new one apart while dropping the steering column wiring the car. Can someone post a picture or link to one that shows a complete power steering rag connection for a '68 Nova?
Thanks, Larry
Old 08-25-2006, 08:34 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Replace it with this
Steering U joint
Old 08-25-2006, 09:18 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Looks interesting, I'll look at my column end to see if it will work on that end.
They have weld-on and "DD". What would "DD" mean?
Thanks, Larry
Old 08-25-2006, 10:41 AM
I think that means 'double-D' shaft, in other words it is a round shaft with two flats on opposite sides.
power steering Paco Suspension - Brakes - Steering 9 10-31-2006 06:02 PM
F250 brake and steering problem 53LEDSLED Suspension - Brakes - Steering 9 08-03-2006 08:16 PM
Steering Lash Adjustment Problem GCD1962 Suspension - Brakes - Steering 1 12-30-2005 08:23 AM
4x4 steering problem adrock430 Suspension - Brakes - Steering 10 12-05-2005 05:39 AM
Steering clearance problem. Super Chevy Suspension - Brakes - Steering 15 05-12-2004 06:07 PM
